347cid PTE engine after 200 miles.....
Old Jun 10, 2003 | 01:42 PM
Phil97SVT's Avatar
Phil97SVT
Default 347cid PTE engine after 200 miles.....
Well a few of you know I had an issue at the track and bent a couple of pushrods and a connecting rod during my last pass. I decided to build a motor myself. The build went very smoothly with the help of some supporting vendors and a local machine shop.
The motor is my factory block but it has been cleaned up for some new pistons and rings. Assembly went well, all of the clearances were right in spec. Porting the oil pump was pretty easy only taking 10-15 minutes.
I fired the car up last week and came to life. The valvetrain was definitely noisier than before but I am running a slightly different cam. The first 50 miles were pretty easy, taking the car to 4000 getting on the gas at every stop light was definitely fun break in period. Well after 200 miles the motor feels stronger than ever. I am still running dino oil for another 300 mile break in period. Idle is pretty stable, fuel is close but alittle on the rich side. Throttle response is very quick. I am soo excited about getting back to the track. Here is a run down of some parts used:
Diamond Forged -2cc pistons
Eagle H beam ESP rods with upgraded ARP bolts
Clevite rod bearings
Federal mogul main bearings
Comp Cam >230 >.600 ;)
Yella Terra Rockers
Phillip
Old Jun 10, 2003 | 01:44 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: 347cid PTE engine after 200 miles..... (Phil97SVT)
sounds like a monster.... I will have to do a forged bottom end in mine soon
Old Jun 10, 2003 | 01:57 PM
John's vette's Avatar
John's vette
Cruise-In III Veteran
Cruise-In IV Veteran
slightly different ? :lol: :thumbs:
Old Jun 10, 2003 | 02:01 PM
Sir Sel's Avatar
Sir Sel
:cheers: They told me you were da man but I didn't believe em till now. :lol: Excellent job. I want a ride.
Old Jun 10, 2003 | 02:13 PM
Phil97SVT's Avatar
Phil97SVT
Default Re: 347cid PTE engine after 200 miles..... (Sir Sel)
Thanks for the positive words.....There is nothing better to me than driving a car with a engine I built. And boy does it run goooood.
Phillip
Old Jun 10, 2003 | 02:22 PM
see5's Avatar
see5
Aways good to hear what you are up to.
Congrats on the newer and better motor!
Old Jun 10, 2003 | 05:09 PM
Phil97SVT's Avatar
Phil97SVT
I am also in the process of changing the nitrous system. A close friend of mine is an NX dealer and wants to add a pair of NX quad shark nozzles and a 2nd set of solenoids. If the setup holds up it should be pretty crazy having a 100 shot out of the hole and another 150 shot coming online @ 60'. :crazy:
Phillip
Old Jun 10, 2003 | 07:44 PM
benelliwang's Avatar
benelliwang
Wow, sounds great Phil. :cheers:
Is there gonna be any pics and/or write ups?
Old Jun 10, 2003 | 08:07 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
It must be rewarding :cheers: :cool: :thumbs:
Old Jun 11, 2003 | 12:37 AM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Default Re: 347cid PTE engine after 200 miles..... (John Shiels)
:iagree: :yesnod: :yesnod: :yesnod: :thumbs:
Congrats Phil !!!!
joel (Bink) :cheers: :steering:
Old Jun 11, 2003 | 01:32 AM
kevette's Avatar
kevette
:cool: :cheers: Best of luck with the tuning of your fresh powerplant :yesnod: Always is a great joy hearing something you built first fire-up & spring to life :eek: Hopefully everything will go well, and have fun driving your new beast :D Congratulations, You certainly deserve it :cheers:
Old Jun 11, 2003 | 09:31 AM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Default Re: 347cid PTE engine after 200 miles..... (kevette)
Congrats on the new motor :cheers: and hope you get that 10 sec motor pass :cool: I know you have of time sweat, and time in the car.
Just please don't tell me its a Ford motor as its a 347 and your screen name has SVT. :jester
Old Jun 11, 2003 | 10:31 AM
MattG's Avatar
MattG
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
Default Re: 347cid PTE engine after 200 miles..... (93Polo)
Awesome work Phil!! :thumbs:
To 347cid PTE engine after 200 miles.....
