turn signal help!!
Old Jun 11, 2003 | 07:03 PM
boost2much's Avatar
boost2much
Default turn signal help!!
Sometimes my turn signals will not turn on. They don't even blink in the guage cluster. I did notice that if I push the hazard lights on then off while the stalk is up or down, they will start to work again. I don't remember seeing anyone having this problems before. Any suggestions? :confused:
:cheers:
Old Jun 12, 2003 | 01:36 AM
PewterVette's Avatar
PewterVette
Default Re: turn signal help!! (boost2much)
I had the same problem a couple of weeks ago. Sometimes my turn signals would work, sometimes they wouldn't work at all, and sometimes they would come on and then pause for a minute or two and then start working again. Replacing the hazard switch fixed the problem and it only cost $35. I had the dealership replace mine but it can be done yourself, just takes time.
There may be an easier way to replace the switch, however, due to the crappy GM design, the whole plastic covering around the hazard switch, stereo, ac, ect. had to be taken off to get access to the hazard switch.
Adam
[Modified by PewterVette, 6:45 AM 6/12/2003]
[Modified by PewterVette, 7:35 AM 6/12/2003]
Old Jun 12, 2003 | 09:19 AM
TorchRed99Coupe's Avatar
TorchRed99Coupe
:cheers:
I am having the same problem. If replacement is the only fix, is there a better switch than the stock one? I'd like to do this only once.
Old Jun 12, 2003 | 01:31 PM
Turbo5's Avatar
Turbo5
My car is in the shop for the turning signal fix right now.
Turbo5 :eek: :eek: :eek:
Old Jun 12, 2003 | 02:46 PM
911ing's Avatar
911ing
Default Re: turn signal help!! (Turbo5)
I'm having this problem also... I just associated it with a flasher or relay getting weak... Thanks for the info!! :cheers: :thumbs:
To turn signal help!!
