can I run 18s all around?
Old Jun 11, 2003 | 08:02 PM
FLYNAVY30's Avatar
FLYNAVY30
Default can I run 18s all around?
I want to put 18 x 9.5s in front and 18 x 10.5s in back...will this cause any problems in terms of the computer...speedo, etc??? Thanks for the help!
Old Jun 11, 2003 | 09:20 PM
HIGHRPM's Avatar
HIGHRPM
Default Re: can I run 18s all around? (FLYNAVY30)
Not if you use tires that keep the overall diameters close to stock. I think the wheel speed sensors have to see a 9+% difference in front to rear wheel speed for several seconds before they trigger an error code. I have 18x9.5 front w/275/35/18 tires (25.6") and 18x12 rear w345/35/18 rear(27.5")....no problems.
1.9"/25.6" is only a difference of 7.4%...not enough to trigger a code.
Old Jun 11, 2003 | 09:33 PM
robsvette's Avatar
robsvette
Default Re: can I run 18s all around? (HIGHRPM)
yeap they fit with no probs. thats what i have
Old Jun 11, 2003 | 09:34 PM
99C5Richie's Avatar
99C5Richie
I haven't had a single problem with my 18"... check my sig for sizes...
Old Jun 11, 2003 | 09:40 PM
TIKTGTR's Avatar
TIKTGTR
Default Re: can I run 18s all around? (99C5Richie)
:sad: I wish I had 18's all the way around!! Makes the car look really low :eek: Good luck!! :thumbs:
Old Jun 11, 2003 | 10:34 PM
COBrien's Avatar
COBrien
Cruise-In III Veteran
St. Jude Donor '06-'07-'08
:iagree: Yep, the only thing that matters is the overall diameter. Stock the difference front - back is about 1"; as long as you are relatively close, you won't have a problem. I've got 265/35s front, and 295/35s on the back, and have had no trouble at all.
Good luck,
Collin
Old Jun 11, 2003 | 11:35 PM
FLYNAVY30's Avatar
FLYNAVY30
ok, sounds good, thanks for the help
Old Jun 11, 2003 | 11:38 PM
FLYNAVY30's Avatar
FLYNAVY30
so should I run 265/35/18s up front and 295/35/18s out back?? Thanks
Old Jun 11, 2003 | 11:42 PM
COBrien's Avatar
COBrien
:yesnod: I like that combination...particularly in the BFG KDs!!
Old Jun 11, 2003 | 11:50 PM
FLYNAVY30's Avatar
FLYNAVY30
ok, sounds good...Ill be goin with the Kuhmos (just graduated college = still poor)
Old Jun 12, 2003 | 03:02 AM
4DCYKEY's Avatar
4DCYKEY
I like the 275/35s up front because they approximate the stock 17" diameter and because they provide a little more sidewall to handle the potholes in CA's roads and hiways...
Old Jun 12, 2003 | 07:45 PM
RCswish's Avatar
RCswish
Default Re: can I run 18s all around? (4DCYKEY)
:iagree:
Old Jun 12, 2003 | 07:52 PM
C5 StockSwap's Avatar
C5 StockSwap
Cruise-In V Veteran
St. Jude Contributor
I emailed you a spreadsheet with tire aspect ratios. It may help you to see the overall dimensions of wheel/tire combinations and wheel widths more clearly. I got it from the forum last year.
Old Jun 12, 2003 | 08:23 PM
FLYNAVY30's Avatar
FLYNAVY30
thanks...that was a big help
Old Jun 12, 2003 | 08:35 PM
robsvette's Avatar
robsvette
Default Re: can I run 18s all around? (COBrien)
yeap, same exact set-up i have
To can I run 18s all around?
