What temp does your car run at??
Old Jun 12, 2003 | 03:03 PM
FLYNAVY30's Avatar
FLYNAVY30
Default What temp does your car run at??
Just curious, mine runs at around 194 and can get over 220 while sitting in traffic according to the computer. I was just wondering if this is normal cause Im moving to FL in August and was thinking about upgrading to a Be Cool radiator before I move. Any thoughts? Thanks
Old Jun 12, 2003 | 03:21 PM
sboxster's Avatar
sboxster
Default Re: What temp does your car run at?? (FLYNAVY30)
187
Old Jun 12, 2003 | 03:29 PM
Richin Chicago's Avatar
Richin Chicago
I don't think you have anything to worry about. I don't believe the fan even comes on until 230.
Old Jun 12, 2003 | 03:47 PM
C5 StockSwap's Avatar
C5 StockSwap
Cruise-In V Veteran
St. Jude Contributor
Default Re: What temp does your car run at?? (Richin Chicago)
Mine usually tops out at 178 under heated conditions. 160 Thermo with fans reprogrammed.
Old Jun 12, 2003 | 03:59 PM
extremecorvette's Avatar
extremecorvette
I wouldn't but a different radiator in, save your money. I would try putting distilled water and new anti freeze with 80% water 20% anit freeze, also Redline Water Wetter may help. The Redline is just an additive you add to you coolant. I don't think your going to have a problem, but if you want to try 160-170 degree thermostat that will do the trice, and if you want to go over board you can have your fans rest to come on at a lower temp. It all depends on what kind of driving your going to do
Old Jun 12, 2003 | 04:09 PM
mozart's Avatar
mozart
Default Re: What temp does your car run at?? (extremecorvette)
Your right in the ballpark with your temps, thats normal range. I think the stock fan is programmed to come on at 234 degree's. If I get stuck in fraffic mine will run right up to about 232 then the fan will kick in and the temp comes down real quick to about 200-205 degree's. If you turn your a/c on it will start coming down immediately as that causes the fan to run regardless the temp.
Old Jun 12, 2003 | 04:53 PM
BayouVette's Avatar
BayouVette
Default Re: What temp does your car run at?? (C5 StockSwap)
Same here. :yesnod:
Old Jun 12, 2003 | 05:35 PM
MRCoupe2002's Avatar
MRCoupe2002
I live in FL already and I see the same temps that you do on a daily basis. It's rare that I sit in traffic for long, but the temperature does get up there if I don't have the A/C running. Since I almost always run the A/C on the days where the outside temp is > 85 - my coolant temperature almost never goes over 208 - 210. It only gets that high if I am stuck in traffic because of an accident in the dead of summer (which I try to avoid since I hate sitting in traffic).
Old Jun 12, 2003 | 05:39 PM
C5-JIM's Avatar
C5-JIM
Your cooling fans have 2 speed motors through 3 sets of relays, so you have little to worry about. C5JIM :cheers: :cheers: :cheers:
Old Jun 12, 2003 | 06:59 PM
carpe dm's Avatar
carpe dm
:iagree: You are OK. Mine runs at 194-196. I have my fans set to come on in the low 200's so it doesn't get too hot. :)
Old Jun 12, 2003 | 10:43 PM
Joe97's Avatar
Joe97
it runs right around 187 degrees
Old Jun 12, 2003 | 11:13 PM
CRAIGVETTE's Avatar
CRAIGVETTE
Veteran: Coast Guard
Senior Member
Cruise-In V Veteran
I live in Florida already, and I put on a 160 thermostate and added Redline Water Wetter, and my temp is usually 178, a big improvement. I haven't even adjusted the fans yet, so I don't think you will need a new radiator. If you don't like your car running in the 200's, and I didn't, then just put in a 160 thermostate. Welcome to the sunshine state :cheers:
To What temp does your car run at??
