Muffler Alignment....whats it take?
Old Jun 12, 2003 | 10:31 PM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
Default Muffler Alignment....whats it take?
Ive noticed alot of C5s that have uneven mufflers. Why is that and whats it take to get em straight?
Old Jun 12, 2003 | 11:13 PM
clancy's Avatar
clancy
Default Re: Muffler Alignment....whats it take? (SurfnSun)
Set them where you want them, then tac weld the pipes where the clamps are. The clamps are slipping. This is the most common reason & the easiest way to solve the problem. :cheers:
Old Jun 12, 2003 | 11:15 PM
Bugster57's Avatar
Bugster57
Usually it's vertical mis-alignment, use washers at the under bumper attachment points to space down the higher of the two mufflers.
Otherwise loosen the forward flange mounting bolts and rotate the mufflers, only a slight bit of play is available.
If these don't work get a muffler man to warm his torch.
Old Jun 12, 2003 | 11:37 PM
don.69z28's Avatar
don.69z28
Cruising
when I installed my z06 exhaust on my 99 hardtop it took me half a day and it still is not that good. My left side was lower than the right as I have noted on other c5's so it stands to reason that the new/take off z06 system would also be off and it was. I elongated the holes in the flanges of the stock pipes and shimed the mounting bracket on the right side to lower the right side to beter match the left. I them preloaded it more than I liked while tourqing the flange bolts and it is still off a bit. BTW with the old black oval tips the misalingment between left and right was not too noticeable as you can guess with crome tips the difference is very noticeable.
Old Jun 13, 2003 | 10:14 PM
carlmorrell's Avatar
carlmorrell
I asked the same question on this forum a few months back and got quite a variety of suggestions.
The approach I took that worked for me, is the rubber thingy (that's a technical term) that the strap goes into has another slot that is not cut all the way through. I removed the rubber with an xacto knife and was able to fix a misalignment that I would not have thought possible.
Another suggestion is to bend the strap. I was not aware the strap could move, so next time I am underneath, I plan on looking at that.
Old Jun 14, 2003 | 02:47 PM
abigfoot's Avatar
abigfoot
Default Re: Muffler Alignment....whats it take? (carlmorrell)
I just had the ZO6 exhaust installed at Midas ( Don't laugh they new exactly what they were doing) I was concerned about lifting the vet and they had me drive up on 2x6's and lifted it with pucks all the way around. My alignment on the tailpipes was off, a lot. The guy heated up the torch and heated it up at an elbow, he then pulled it into place effortlessly. :thumbs:
To Muffler Alignment....whats it take?
