After heavy acceleration the clutch will not come back up all the way - I have heard many people speak on this but i do not recall seeing an actual "fix".
The Stealer said they have run into this problem before and stated they knew what it was.
I just got my car back from the stealer, they replaced the master and slave cylinders and i took the car out for a run and the problem still exists???
Is there something i can reference them twards? I already mentioned about wrapping the lines with some type of heat resistant wrap but they just looked at my funny.
Re: Clutch Question - Not coming back up? (99firetruck)
I have recently heard about a problem very similar to yours. The owner of the COrvette in San Jose CA. clinic told me that the brake fluid used for the clutch tends to "wax" after hard use. This has resulted in a total overhaul of his hydraulic system for the clutch. He told me to switch to a brand of fluid called "Super Blue Racing" from Germany. I just checked my clutch slave cylinder and noticed a ring of "waxing" fluid inside. I am going to change the fluid the first chance I get. I thought he was giving me a line of BS to sell me some exspensive fluid. It sells for approx. 18 dollars a qt. I purchased a qt. and will change it the first chance I get.
Re: Clutch Question - Not coming back up? (Scubanme)
I have heard similar to this. My concern is since they replaced the master and slave cylinders (so they say), they would have to flush the system (i think)..... So in theory - it is still happening with Brand New Fluid.
Would be very interested in finding out the cause. I have had this problem with my 2000 vette for months, have made numerous trips to the dealer, his only answer was that I had air in the lines. They bled the system but that did not resolve it. Continues to happen under had acceleration
:confused:
I have always heard that this issue is due to flaws in the pre-'02 slave and/or master. Certainly they would have used the updated parts when they did the work so I'm pretty suprised that the issue is still there.
Re: Clutch Question - Not coming back up? (5 Liter Eater)
Everyone has there own theory. Thruth is there is a service bulletin out for it now and it can be resolved under warranty, etc.
I had mine done and I have not had a problem since. The wax theory is the first time I heard that, but usually most people update to the 02 slave and master.
It is a combination of things. Some will say it is a restriction in the lines, but people modify their lines and still have the problem.
All in all the almost sure fire way to fix the problem is by updating your master and slave to the new 2002+ (it should be the same for z06 and for normal c5's)
Also c4c5specialist had a post sometime ago (do a search) about this problem and what GM was doing to address it. Because of his help I had mine fixed under warranty. If you are out of warranty you may want to change your clutch at the time they replace this stuff, because it requires the same labor!!!!!
Does anyone know the service bulletin # or where to locate a copy of it. My dealer says he hasn't seen it.
Contacted another dealer and he said this was a U/I (Unpublished Information) document, not a service recall. It does in fact call for replacement of the master and slave cylinders as well as Inspection of the finger of the pressure plate for damage. It should all be covered under warranty :cheers:
Re: Clutch Question - Not coming back up? (ICUALL)
I am not uncertain of what parts they used, but they did replace the slave and master with no resolution...
they mentioned that it is NOT covered by my Extended warranty - but they did it under some post factory warranty grace period thing? In other words - sorry we screwed up your front bumper - well take car of the clutch.
From: Alhambra Calismognazifornia, in the country everyone comes just to complain but won't go back home!
i have an '02 and i have the same problem so that fix is :bs
i had the pedal return spring break on me once already but putting a new one in didn't do a damn thing. my only guess would be a weak clutch plate that can't handle the extra heat build up of hard driving. i'm going to take it in soon to get checked. if they feed me a line of the same crap i'm just gonna change it out for a SPEC clutch and be done with it.
anyone that finds a solution other than the changing to '02 stuff please be sure to keep us all informed :cheers:
Re: Clutch Question - Not coming back up? (Walt Donovan)
You guys with the no-come-back clutches - Is it only at big RPMs, like a WOT shift?
That's how it is for me. Mine comes back up but when you press it again, it goes halfway to the floor before it meets any resistance.
If I don't drive the car for a couple days, the clutch is super easy to push in but after about 5-10 minutes it's back to normal, a lot harder at times and inpredicatable. I felt the clutch of my friend's new '03 Z06 and it was like butter, much better!
Same with my only seems to occur at high rp's under heavy acceleration. The dealer is willing to change out the parts as listed in the U.I. document, but it has to wait until after the 50th Caravan I leave Monday Morning for Nashville.
You guys reallize that non-returning clutches at high RPMs is a characteristic of diphragm clutches, right? They go overcenter and centrifugal force holds them disengaged. Some aftermarket pressure plates and maybe Z06 address this. Is it possible that's what your experiencing?
This is what I gave to my dealer and it was all done under warranty.
Sticking Clutch – Clutch will not fully return under hard acceleration and high RPM shifts – VME# P100206 Please replace with 2002 Z06 Clutch Assembly Part # 012570806, Slave Part # 012562767, Master Part # 012564455
Yes I know this is common with diaphram clutches however chevy has been using them for 30-40 years and I had hoped they had the bugs worked out.
:banghead:
You are absolutly right, the over centering has been a problem on some aftermarket clutch pressure plates also.
I would think you should be able to fix this with an adjustable Master Cylinder. If you adjust it so it engages closer to the floor it should help the problem. It then wouldn't disengage it too far(push the diaphram fingers over center)
I don't know if anyone has tried an adjustable master cyl on a stock pressure plate yet or not?? might be worth a try 'cause its easy to do
I recently had this happen on my 99, are you sure its not covered under the extended warranty?
