Auto Trans Fluid Change
Old Jun 16, 2003 | 07:50 PM
WhiteC5Vette's Avatar
WhiteC5Vette
St. Jude Contributor
Default Auto Trans Fluid Change
Is there anyway to remove all the trans fluid, including torque converter, in order to switch over to synthetic fluid; without removing the trans? Is there a drain plug in the torque converter?
Would like to switch to synthetic, but can't believe I would benefit unless I was able to remove all fluid, including fluid in the torque converter.
Thanks.
Old Jun 16, 2003 | 07:58 PM
sbkim's Avatar
sbkim
Default Re: Auto Trans Fluid Change (WhiteC5Vette)
From what I've gathered from various tuners is stick with non-synthetic tranny fluid due to potential slippage issues with using synthetic. Personally I have been running Mobile 1 ATF for about 3 years with no noticeable issues.
I am getting ready to do stall and gears in a couple weeks and plan on doing tranny flush - prob the only way to get all the old fluid out with GM non synth tranny fluid and new filter
Good luck
Old Jun 17, 2003 | 09:56 AM
reddon's Avatar
reddon
Default Re: Auto Trans Fluid Change (sbkim)
The only way is to do a flush with synthetic fluid. It will use a lot of fluid to flush the system. I had them do this when I had the TransGo shift kit installed and it worked great. I use the Mobil 1 ATF.
To Auto Trans Fluid Change
