Anyone try a reverse split cam or thought about it...?
Old Jun 17, 2003 | 11:49 AM
MeatheadsC5's Avatar
MeatheadsC5
Default Anyone try a reverse split cam or thought about it...?
Anyone.... bueler...
Old Jun 17, 2003 | 12:37 PM
nevrenuf's Avatar
nevrenuf
LS1Edit Guru
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: Anyone try a reverse split cam or thought about it...? (99Mongoose400SS)
Yes, I have run two different ones.. I replaced a typical single pattern cam with a reverse split and lost NO horsepower (within 3 of the single pattern) but picked up 50 ft-lbs of torque.
Since then, I have experimented with a few more radical reverse splits, with similar results.
I am a fan of these cams.. pick up torque at no loss to horsepower...
I have two for sale right now.. my last two.. I just keep going bigger and bigger...
Old Jun 17, 2003 | 12:41 PM
NEED FOR SPEED's Avatar
NEED FOR SPEED
CI 3-4-5-6-7-8-9-10 Vet
St. Jude Donor '07
Default Re: Anyone try a reverse split cam or thought about it...? (nevrenuf)
Tom, what are the specs on the cams you tried? What would you suggest for a stock bore and stroke?
Old Jun 17, 2003 | 12:51 PM
kromberg's Avatar
kromberg
The reverse split was a big fad a little bit ago. It seems that split cams like the G5X2 are becoming popular. Once a cam is posted that it performs good for an application, everyone jumps on it like sheep.
Keith
To Anyone try a reverse split cam or thought about it...?
