Header Shoot Out Post your before and after dyno numbers and Vote
I want to see what your getting for peck Hp and Tq gains also what gains they’re getting under the curve. I’m looking to see what gains your getting from just headers, so post the mods the car had before and after, and what extra mods you did between those dyno’s besides headers. I know some headers come with hi flow cats, X pipe, and pipes so you can remove the cats completely. I know Kook is coming out with headers in 6-8 weeks and I hear Borla are coming out with XR-1 headers. Thanks
Vote on the best headers also.
Re: Header Shoot Out Post your before and after dyno numbers and Vote (extremecorvette)
I had 369.4 rwhp and 359rwtq with just a blackwing and loudmouth exhaust. I added the FLPs header system with highflow cats and got 362.7rwhp and 358.9rwtq. No tuning was done but still I should have gained some sort of hp and really didnt expect a loss. Oh well that crappy FLP set up is off my car now. They are such a horrible product, first they come in all scratched and beat up and I have to go through hell to get em replaced (its nice that the company blames the customer for the scratches even though according to my tracking number i had them for 5 minutes before I called), then they dont perform when I finally get a set in new condition. Now I see they are having quality problems again....doesn't surprise me at all but thats what you should expect from Finish Last Performance
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
Re: Header Shoot Out Post your before and after dyno numbers and Vote (kh24)
I picked up 15rwhp/5rwtq peak from my Stainless Works Headers, Xpipe and Muffler system over the TTS Headers, custom off-road Xpipe and B&B Route66 system I had before.
Re: Header Shoot Out Post your before and after dyno numbers and Vote (MattG)
99 FRC Vette Mods before headers Blackwing intake and B@B PRT exhaust
310 RWHP
315 RWTQ
After FLP Headers
335 RWHP +25 HP
345 RWTQ +30 TQ
Then LS1 EDIT tuning
344 RWHP
356 RWTQ
:D
310 RWHP
315 RWTQ
After FLP Headers
335 RWHP +25 HP
345 RWTQ +30 TQ
344 RWHP
356 RWTQ
:D
Re: Header Shoot Out Post your before and after dyno numbers and Vote (Mike TexaSS)
I lost 9 peak hp and upto 35ft lbs of toque from 2000-4500 rpm from my Cartek headers and Stianless Works exhaust.
BTW I have a 395 stroker.
[Modified by kumar75150, 1:58 AM 6/18/2003]
Re: Header Shoot Out Post your before and after dyno numbers and Vote (kumar75150)
I lost 9 peak hp and toque from 2000-4500 rpm from my Cartek headers and Stianless Works exhaust.
Thats so weird man. How big of a motor is he running? I am going to try a bigger cam to see if that will help.
BTW I should edit my original statement.
I lost 9 peak hp at 6200ish rpm. I also lost from 20-35tq between 2000-4500rpm. I figured I would lose some torque but the peak loss kinda has me confused.
kumar,You must have a tuning issue or your particular set up doesn't like the bigger diameter,I gained 12 Peak and up to 30HP at some rpm's under the curve,with my Cartek 1-7/8,headers.
Re: Header Shoot Out Post your before and after dyno numbers and Vote (TEK WARRIOR)
with the old stock motor last year, with standard minor bolt-on junk like intake, maf, cat-back, here's my results with the FLP full system with high their high flow cats:
Before:
323rwhp
341rwtq
After:
350rwhp
366rwtq
a 27rwhp/24rwtq gain. NO EDIT TUNING, either, at this point, just MAFT. I would not get Edit for another couple months. I was very impressed. Plus, I like the V-clamps. However, the accuracy and quality of workmanship is not perfect. I've aleady had a collector retain tab bust completely off the driver side header. I had to have the hole welded up which ruined the nice ceramic finish. oh well, i'm about the performance, not looks.
Before:
323rwhp
341rwtq
After:
350rwhp
366rwtq
another current, related, complimentary thread: http://forums.corvetteforum.com/zerothread?id=585633
Re: Header Shoot Out Post your before and after dyno numbers and Vote (tattooed)
I went from 368.6rwhp/359.7rwtq to 381.3rwhp/373.4rwtq using the tpis headers. I have since changed over to the carteks (getting ready for the 408)
And havent had the car dynoed since then. I do think it will hurt me on motor but should help on nitrous. :cheers:
Kumar you lost hp/tq with the Carteks? Man that sucks.I would have thought the headers is what was holding you back. Are you using nitrous on you car?
[Modified by MY1Fast99C5, 6:17 PM 6/18/2003]
Re: Header Shoot Out Post your before and after dyno numbers and Vote (MY1Fast99C5)
No nitrous YET. :D
I am not sure yet whether I am gonna keep the Cartek or switch back to TPIS or shell out the money for some Stainless Works.
With the mods listed, added new plugs & FLPs with cats.......
Before
With new plugs & FLPs
Picked up 25+tq in some areas, but a real nice curve.
Picked up over 3/10ths in the quarter too! :yesnod:
Before
No nitrous YET. :D
I dynoed with new Stainless Works headers installed and:
A>with the filter element removed in the PCV (CH)
B>With the filter element installed, not cleaned and unmodified.
Previous run with PCV and mods in sig, less headers--369HP&355/TQ
Today run 1 without element in PCV and SW headers and cats--384HP&371TQ
Today run 2 with element and headers--- 385HP&372TQ
Run 3 same as 2 above
So the PCV mod makes no difference and the SWs add ~16HP&17TQ without tuning.
I am running about 14 A/F at peak HP so another tune is in order.
Before TTS headers 308hp/330 tq. Only Vortex and SLP Loudmouth.
After TTS install only 334hp/350tq.
Predator tuning gave me another 3-5hp/tq :confused:
Gains followed the factory curve almost exactly with the increase levels.
Re: Header Shoot Out Post your before and after dyno numbers and Vote (JoeyG)
We just installed the Stainless Works Headers with the 3" mid-section and are very pleased with the results. The car gained aprox 20hp and 20 Ftlbs/tq but what is most impressive is that the gains are from just over 2k to redline!! No-where did the car lose any tq/hp at all... Click on the dyno graph below to see the difference between when the car had a stock exhaust system and now with the Stainless Works. BTW, the cat-back is the Z-06 TI system.
Max Power before headers: 367.99 / 361.41 TQ
Max Power after SW Headers: 384.74/ 379.00 TQ
Dyno conditions: 99.2 degrees/44% humidity/104degrees IAT Temp/204 Coolant Temp/30.12"/ All dyno measurements are SAE.
[Modified by BlkFRC, 10:30 PM 6/21/2003]
