C5 Shifting issues
Old Jun 17, 2003 | 01:01 PM
tkemory's Avatar
tkemory
Default C5 Shifting issues
Was curious if anyone could help shed a little light on a constant problem I am having with my vette in regards to changing gears. If possible, what may be causing the problem, and what I will need to get it fixed (estimated cost).
When shifting my corvette it feels *rough* moving between certain gears, at the shifter. There are no grinding noises or difficulty with the clutch, its using the shifter and it almost feels like the shifter is providing the resistance. Sometimes it doesn't even like going into first gear without first moving through other gears, often going into the reverse gear fixes the problem. Sure that freak out the people behind me at a stop light.
It seems like its gradually getting worse and I would like to get it fixed but I like to have an idea of what I am in for financial wise for budgeting reasons. I hate the just bring it in we can tear into your transmission and figure it out statement, someone has to be able to make an educated guess from the symptoms.
Thanks in advance
[Modified by tkemory, 12:01 PM 6/17/2003]
**Oops forgot to add signature and it wont add on the edit so here is the information on the car
1999 C5 Coupe, Borla Exhaust and Blackwing filter, stock otherwise...
[Modified by tkemory, 12:02 PM 6/17/2003]
Old Jun 17, 2003 | 08:07 PM
aaaa's Avatar
aaaa
Default Re: C5 Shifting issues (tkemory)
Bleed your clutch
Old Jun 17, 2003 | 09:46 PM
speedyc5's Avatar
speedyc5
Default Re: C5 Shifting issues (aaaa)
Bleed your clutch
:iagree: :iagree: :iagree:
:auto: :auto: :auto:
Old Jun 18, 2003 | 08:27 AM
tkemory's Avatar
tkemory
Default Re: C5 Shifting issues (speedyc5)
Thanks for the replies,
I am not a very mechanical person, but I assume that means release the fluid? More than likely I will take it in and have someone do it, what would something like this run?
I dont have the setup or knowledge to tinker too much under my vette, which handcuffs me unfortunately.
Old Jun 18, 2003 | 08:59 AM
User 81424's Avatar
User 81424
It should not be more than an hours worth of labor and some fluid.
Old Jun 18, 2003 | 09:47 AM
tkemory's Avatar
tkemory
Default Re: C5 Shifting issues (CPT Z06)
Thanks for the info, I will let you guys know how it turns out!
To C5 Shifting issues
