Clutch Question
Old Jun 17, 2003 | 03:32 PM
benelliwang's Avatar
benelliwang
Default Clutch Question
I've got a Ram Clutch set up with Ram Steel Flywheel. I read that people are 0 balancing the setup up. So I called a local machine shop recommended by a friend. The shop wants the crank inorder the 0 balance the Flywheel to the clutch. Does this make sense?
thanks
Old Jun 17, 2003 | 05:25 PM
BSiegPaint's Avatar
BSiegPaint
St. Jude Donor '06-'07
Default Re: Clutch Question (benelliwang)
I would say no - if the engine is internally balanced (it is), and you attach something to it that is balanced (you will) it should be balanced as a unit, shouldn't it? I understand if the engine is externally balanced, as you would throw off the weights attached to the balancer on the front, etc., but not for this application. Someone correct me if I'm wrong...
Old Jun 17, 2003 | 07:52 PM
aaaa's Avatar
aaaa
Default Re: Clutch Question (BSiegPaint)
Doing the entire rotating assembly is the best-most don't do it.
Old Jun 18, 2003 | 01:14 AM
bparker's Avatar
bparker
That is silly and no you dont need to do the crank with it.. :cheers:
Old Jun 18, 2003 | 03:29 AM
aaaaa's Avatar
aaaaa
Default Re: Clutch Question (bparker)
If you had your engine balanced and blueprinted the shop would want to do it with the flywheel and clutch assy. It's not absolutely necessary unless you want it "perfect"
To Clutch Question
