what size tires for kuhmos
Old Jun 17, 2003 | 05:14 PM
troy'sC5's Avatar
troy'sC5
Default what size tires for kuhmos
i have the z06 wheels on already so should i go with 275/40/17 (how does that look) and 295/38/18
Old Jun 17, 2003 | 09:34 PM
SteveL2's Avatar
SteveL2
Default Re: what size tires for kuhmos (troy'sC5)
The odd thing is, Kumho sells their ECSTA MX for the rears in Z06 size, but they don't sell that tire for the fronts in Z06 size -- or, at least, this is what Discount Tire told me and it's what's on Kumho's website (http://www.kumhousa.com/). Instead, for the fronts, they sell a ECSTA Supra. I don't know the difference between the Supra and the MX, but they certainly have a different tread pattern. Go figure?? :confused:
Old Jun 17, 2003 | 09:44 PM
chuckster's Avatar
chuckster
Default Re: what size tires for kuhmos (SteveL2)
Don't Mix them
Either use the 255 or the 275 for the front if you have Z06 Rims
Old Jun 17, 2003 | 10:54 PM
pitrider's Avatar
pitrider
Default Re: what size tires for kuhmos (chuckster)
I installed a set of Kumho Mx 275/40/17 fronts and 295/35/18 rears on stock 02 Z06 rims last month..work awesome and look great
Old Jun 17, 2003 | 11:52 PM
Johnny Vig's Avatar
Johnny Vig
Default Re: what size tires for kuhmos (MX-QUICKSILVER-01)
If you go with the 275/40-17 tire upfront and a 295/35-18 in the rear your sidewall will be bigger up-front. Go to the website below and you can enter the tire sizes and then see the specs. Many have settled with the 275/40 size, I instead went with 18x9.5 rims up-front with a 265/35-18 tire. Make sure you like the look before you buy them. Best of luck.
Tire calc website- http://www.miata.net/garage/tirecalc.html
[Modified by Johnny Vig, 12:06 AM 6/18/2003]
Old Jun 18, 2003 | 12:37 AM
BQuicksilver's Avatar
BQuicksilver
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: what size tires for kuhmos (Johnny Vig)
I plan on using a 255front 295rear setup when the day comes for a change.
To what size tires for kuhmos
