Is there a major difference between....
Old Jun 17, 2003 | 10:04 PM
LittRedCorvette's Avatar
LittRedCorvette
Default Is there a major difference between....
I have a chance to pick up a set of stock 98 f body heads and was wondering if they were able to be switched with my stock 02 corvette heads......after major work done to them of course.......
Old Jun 18, 2003 | 02:21 AM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: Is there a major difference between.... (LittRedCorvette)
F-body LS1 heads and C5 heads are the same.
Here are the differences:
97 - 98 use a perimeter valve cover bolt design. Thus requiring perimeter bolt valve covers and coil brackets specific to that style.
99+ use center bolt valve covers with coil brackets specifc to that style.
Otherwise all LS1 heads are identical.
Old Jun 18, 2003 | 02:33 AM
Mitch C's Avatar
Mitch C
Default Re: Is there a major difference between.... (kewlbrz)
:iagree:
To Is there a major difference between....
