I dont Get Hydro locking
Old Jun 18, 2003 | 10:28 AM
skidmarc's Avatar
skidmarc
Default I dont Get Hydro locking
I just drove the vette home an hour in the rain (sorry guys had date and didnt know it was gonna rain overnight..lol) I have the Vortex Ram Air....I did encounter some heavy rain and a lil mild flooding.....When I got home I took apart the power duct/TB......no water at all.....there were a few drops in the vortex box......so in conclusion why would one worry about driving in the heavy rain with a vortex??? I would guess you would have to drive thru some fairly deep water at an ignorant speed to get H20 up the duct into engine....am I wrong???? What am I missing???? Isnt hydrolocking getting water up the air duct into TB/Intake down into heads???
Old Jun 18, 2003 | 10:41 AM
Duck916's Avatar
Duck916
Default Re: I dont Get Hydro locking (skidmarc)
A motor will hydrolock when it consumes enough water (or other incompressible fluid--motors have hydrolocked from gas leaking from the carb overnight) to allow more liquid in the combustion chamber than the combustion chamber can hold at TDC. If you had 55cc combustion chambers and 60 ccs of water was in the cylinder when the intake valve closed, well, hello bent rod.
I think it's pretty well established that you're only gonna risk hydrolocking if you drive through a very deep puddle with a bottom breather intake. Heavy rain alone won't do it.
Old Jun 18, 2003 | 10:47 AM
Mitch C's Avatar
Mitch C
When it is raining hard pot holes can get filled with water and can create deep puddles that you can't see as you are driving along. If you hit one of them and your Vortex sucks up the water good bye engine :( . Forum member Redgar hydro locked his engine while driving slowly thru a parking lot. You don't have to be driving like a maniac to hydro lock your engine.
[Modified by Mitch C, 2:33 PM 6/18/2003]
Old Jun 18, 2003 | 12:47 PM
MC TORCH RED's Avatar
MC TORCH RED
Default Re: I dont Get Hydro locking (Mitch C)
POOR EDGAR.. :mad
Old Jun 18, 2003 | 07:46 PM
r1hooligan's Avatar
r1hooligan
I hydrolocked my last car which was a turbo 300zx. It was at night and I was driving home on a road that I knew very well. Well all these cars slowed down in front of me and I was behind an SUV. I didn't see the deep water, estimating less than 12 inches of water, but the splashing from the stop and the cars around me must have made it suck it up. This bent some rods and cracked my block. The dealership wanted $11 grand to fix it. So I sold it to my mechanic for $4 grand and got a vette. Point is that I didn't expect it at that area and I got stuck behind an SUV. Now, I wait for the storm to pass because I have a vortex. :D
Old Jun 19, 2003 | 12:27 AM
Duck916's Avatar
Duck916
Don't forget, if you have comprehensive coverage on your insurance policy, that should cover this sort of damage.
Old Jun 19, 2003 | 12:39 AM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
What you're missing is this thing your engine creates called vacuum. You don't have to drive fast, or heck, be moving at all to hydrolock. You don't have to "force" the water all the way up into your engine....your motor is like a giant shop vac and will suck it up all on it's own. If you were to completely submerge the intake, you're done, instantly. The motor will simply stop. There is no reaction time involved.
Taking apart your intake ducting to check for water after the fact doesn't do a bit of good, other than tell you you were damn lucky if you found water inside and your engine still runs. A couple drops of water ingested here 'n there won't hurt...you would have to get into some pretty deep water to really suck up enough to do damage.
The Halltech TRIC was one of the worst for this situation, as the intake filter resided just inches off the ground. Your Vortex is much safer in that respect, but as always, your best defense is to not drive through any standing water.
:cheers:
Old Jun 19, 2003 | 01:22 AM
EHS's Avatar
EHS
skid:
If you don't get hydrolock, why worry about it?
Sounds like you're good to go.
Enjoy!
Old Jun 19, 2003 | 01:36 AM
NEPTUNEBILL's Avatar
NEPTUNEBILL
Default Re: I dont Get Hydro locking (r1hooligan)
I had the same thing happen at night behind an suv got caught in a downpour going very slow could only see the tail lights of the suv and I was running an MTI bottom feeder at the time, we're talking a major road as well, brand new heads cam engine gone in a instant, rods through the block etc, no bottom feeders for me but the one I had had a large scoop between the car and the airdam under the front so it was like a big scoop 3 or 4 inches off the ground, the vortex rammer should not be a prob compared to this.
Old Jun 19, 2003 | 12:07 PM
fredl11's Avatar
fredl11
Default Re: I dont Get Hydro locking (NEPTUNEBILL)
The Vortex should not be a problem but watch out for the Halltech!! I know, driving on a replacement motor now!! Wife got caught in a deluge and motor went bye, bye.. I would also have some concern with the VRamm setup as it uses the opening by the fog lights.
Luckily our car insurance picked up the bill. There were about 6 Vettes hyrdo'd during that storm, including one Z06. I was hoping they would screw up and put his block in our C5.. Just glad they fixed. Needless to say I am running a different air intake now..
:steering: :party: :steering:
Old Jun 19, 2003 | 12:14 PM
911ing's Avatar
911ing
Default Re: I dont Get Hydro locking (fredl11)
Water isn't the thing you have to worry about...
Being a firefighter, I can tell you that when water converts to steam, it expands 1700 times it's initial volume... so,
take for example, 10 drops of water make it into your combustion chamber... When those 10 drops get hot enough to convert to steam, they become the size of 17,000 drops of water, which is enough pressure to do SERIOUS damage to a motor that already has high compression inside the combustion chamber.
It is a known rule in firefighting that you can put out a room and contents fire confined to one room by opening the door to the room, spraying a short burst of water in a fog pattern into the top of the room, then close the door behind you, and the steam conversion will put out everything in the room via steam conversion smothering the fire, and depriving it of oxygen....
[Modified by 911ing, 11:18 AM 6/19/2003]
Old Jun 19, 2003 | 12:26 PM
jimman's Avatar
jimman
Default Re: I dont Get Hydro locking (911ing)
It's with the bottom feeder intakes and it's at slow speed. Mine was less than 5mph and the two others that I personally know it was the same slow speed. 11K and change and don't count on your insurance all the time.
Old Jun 19, 2003 | 03:43 PM
skidmarc's Avatar
skidmarc
Default Re: I dont Get Hydro locking (jimman)
Sounds like next time I have a date I will be checking the weather up till the next morning :lol:
To I dont Get Hydro locking
