p1133 and p1153 codes
Old Jun 19, 2003 | 01:22 PM
Pitstop1's Avatar
Pitstop1
3rd Gear
Default p1133 and p1153 codes
I had a Corsa Indy exhaust system plus x-pipe installed on 2002 CPE. Now my engine check light comes on. I am getting codes p1133 and p1153, on both the O2 sensors after the cat. Dealer says I need to put the H-pipe back in. Anybody have this problem? If so, what was the correction?
:confused:
[Modified by Pitstop1, 6:25 PM 6/19/2003]
Old Jun 19, 2003 | 01:34 PM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: p1133 and p1153 codes (Pitstop1)
:confused:
Not sure why that system would cause a problem like that. Probably something else.
Those codes simply indicates that the rear O2's arent seeing enough rich/lean activity from the cat, and assume there is a problem. There is no performance problem with this code since the rear O2's dont do anything but monitor. You would fail a OBD-II emissions test tho with those codes if you have that type of test in your area.
Old Jun 19, 2003 | 01:49 PM
Godspeed's Avatar
Godspeed
Senior Member
Cruise-In IV Veteran
Actually P1133 and PP153 is insufficient switching of the B1S1 and B2S1 I believe. We get these two codes with our headers and the solution is to hook up the physical rear O2 sensros in the front spots on the wiring harness - we sell an adapter just for such purpose. The reason being the rears have a higher wattage and heat up faster than the fronts as they are farther away. Then for the rear O2 sensors spots we install the O2 simulators. It's either that or just turn off the codes. The only adverse effect of having these codes is that it could take longer to go from open loop to closed loop as the PCM is waiting for the sensors to heat up.
[Modified by Godspeed, 2:49 PM 6/19/2003]
Old Jun 19, 2003 | 02:10 PM
kewlbrz's Avatar
kewlbrz
Default Re: p1133 and p1153 codes (Godspeed)
Thanks for the clarification Jeremy. I had my codes mixed up.
Old Jun 19, 2003 | 07:10 PM
Pitstop1's Avatar
Pitstop1
3rd Gear
My problem is, with the check engine light coming on for the codes mentioned, I won't know if I have any other problems that might be serious
To p1133 and p1153 codes
