Valve spring compressor tool?
Old Jun 19, 2003 | 10:20 PM
SnowyATX's Avatar
SnowyATX
Default Valve spring compressor tool?
Did a quick search and found this thread: http://forums.corvetteforum.com/zerothread?id=463034
Anyone know where I can get one of these or know of a better alternative?
Any tips on where I can find a cheap spark plug hole fitting for my compressed air hose to keep the valves in place?
TIA,
[Modified by PewterC5, 9:32 PM 6/19/2003]
Old Jun 19, 2003 | 10:38 PM
LoneStarFRC's Avatar
LoneStarFRC
Default Re: Valve spring compressor tool? (PewterC5)
TIA,
It looks like the unit manufactured by Lisle Corp and sold at many auto parts stores. I've seen one with a wooden handle and one without. I think even Sears carries some of the Lisle line too.
The spark plug hole/air fitting is also available at a number of auto parts stores too. HTH
Robert
[Modified by LoneStarFRC, 9:40 PM 6/19/2003]
Old Jun 19, 2003 | 10:58 PM
rwj383's Avatar
rwj383
Default Re: Valve spring compressor tool? (LoneStarFRC)
i made one out of an old shorty flat head crow bar. Works good. But, difficult to work around the cowl when doing #8 intake or #7 exhaust spring. So, I ordered a cool little tool from More Performance: http://www.moreperformanceinc.com/
you can see it is pricey at $130, but a nice tool to have. Or you can take an old rocker and make this tool yourself.
Old Jun 19, 2003 | 11:09 PM
RichM's Avatar
RichM
Just got mine ( and my 918's with the blue stripe) today -$130 - but they throw in the magnetic pencil :hurray:
Rich m
[Modified by RichM, 10:10 PM 6/19/2003]
Old Jun 19, 2003 | 11:34 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Here you go- http://www.napaonline.com/cgi-bin/nc...num.d2w/report. Buy it online ;) :thumbs:
Links not working.Go to NAPAONLINE.com, Enter SER912 for part #.good Luck.
[Modified by binksZ06, 11:38 PM 6/19/2003]
Old Jun 20, 2003 | 12:31 AM
derty's Avatar
derty
Default Re: Valve spring compressor tool? (binksZ06)
Yup, that's my hand in the picture! You can get that from any Napa for about $15. You'll want to consider chopping it down in length just above the hole in the handle. That should make it work just fine. I used a long bolt to draw it down, others use threaded rod. Either one will work, just make sure that you feel confident enough that you have enough threads engaged and crank away. As your cranking down just take a small plastic hammer and tap the lock to get the retainers to unsnap. That's about it.
Old Jun 20, 2003 | 02:54 AM
jmX's Avatar
jmX
Default Re: Valve spring compressor tool? (derty)
PewterC5, I just MSG'd you. I have a brand new style valve spring compressor that just hit he market I wanna try out on some springs and I'd be more than happy to help. I also have access to 2 other styles of compressors so I think I could probably cover all your bases there :)
Check your PM's and email me at the address I sent you.
Jon
http://www.c5howto.com
jmX's Avatar
jmX
Default Re: Valve spring compressor tool? (jmX)
Oh, I have a spark plug air hose fitting too, and I have a thing to hold up all the lifters without magnets.
Old Jun 20, 2003 | 03:26 AM
cfi_luz's Avatar
cfi_luz
Jon
I'm going to be doing a cam install next month so please let me know what compressor ends up working out because I will need to purchase one. thanks
Old Jun 20, 2003 | 03:28 AM
SpinMonster's Avatar
SpinMonster
Default Re: Valve spring compressor tool? (cfi_luz)
Sears and it is under 20 bucks
Old Jun 20, 2003 | 06:03 AM
rwj383's Avatar
rwj383
Jimx;
What's your gadget for holding up the lifters without magnets?? I'd be very interested in this as i use a bunch of magnets....
Robert Judd
Old Jun 20, 2003 | 06:28 AM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Default Re: Valve spring compressor tool? (rwj383)
Robert - check out this thread http://www.ls1tech.com/threads/showf...fpart=all&vc=1 Neat JPR Tool! :yesnod: :yesnod: :thumbs:
To Valve spring compressor tool?
