More air for the Blackwing
Old Jun 20, 2003 | 11:38 AM
2K6Ls2's Avatar
2K6Ls2
Default More air for the Blackwing
What would happen if you drilled holes in the radiator shroud directly under (behind) the Blackwing? It seems to me this would allow a lot more air into intake but I'm concerned about water etc. contaminating the filter. Has anyone tried this?
Old Jun 20, 2003 | 12:02 PM
gpflepsen's Avatar
gpflepsen
Cruise-In II Veteran
Default Re: More air for the Blackwing (2K3Ls1)
If you want to go this route, get the cold air cover and cut out the shroud. Nothing but cold outside air.
[Modified by gpflepsen, 11:03 AM 6/20/2003]
Old Jun 20, 2003 | 12:23 PM
The Batman's Avatar
The Batman
Just to be clear, cutting the shroud will get you colder air, not really "more" air - your unrestrictive air intake/filter gets you more air. Cars generally don't starve for air, the car is submerged in air. No matter how hard your engine or supercharger is sucking in air, there's usually plenty more leaking in somewhere, and the cooler the air leaking in, the better.
Old Jun 20, 2003 | 01:02 PM
tabbruzz's Avatar
tabbruzz
Don't do it as your car will surge......Leave it as is or get the cold air screens for the front..............
Old Jun 20, 2003 | 01:10 PM
RWhite's Avatar
RWhite
Default Re: More air for the Blackwing (tabbruzz)
Ditto the above post. I sent you an IM but do a little search in the Archives and you will get a lot of poop on this subject, mostly negative on the cutting of the hole.
Old Jun 20, 2003 | 02:12 PM
ryan0's Avatar
ryan0
Default Re: More air for the Blackwing (The Batman)
i was amazed to see the smooth coupling i have distort at WOT on the dyno.. it was sucking HARD.
gpflepsen's Avatar
gpflepsen
Default Re: More air for the Blackwing (RWhite)
Hmmm, mine doesn't surge.
To More air for the Blackwing
