Differential failure due to wrong oil!
Old Jun 20, 2003 | 04:01 PM
ElanMike's Avatar
ElanMike
Default Differential failure due to wrong oil!
I got the car back earlier this week from the shop that fitted my new 4.10. At first there was a little noise and this just got louder. The shop had put GM Syncromesh in the differential after talking to a local dealer. They confirmed again with the dealer as they were not convinced. After being assured this was correct, they used it, I dove it and the differential is now toast.
The dealer has taken responsibility and is covering the cost of repalcement. I am still without a car for another week though. :(
Old Jun 20, 2003 | 04:11 PM
Trey395's Avatar
Trey395
Default Re: Differential failure due to wrong oil! (ElanMike)
What did the noise sound like and when did it occur?
also - I thought GM synchromesh was the only approved fluid?
Old Jun 20, 2003 | 04:21 PM
ElanMike's Avatar
ElanMike
Default Re: Differential failure due to wrong oil! (Trey395)
It started off as a rattle from the shifter, which got louder and LOUDER! It sounds like a metal rattle to start and turns in to a loud shreak. It was deafening inside the car and could also be heard very loudly outside the car.
Apparently, Synchromesh is only for the transmission, not the differential. You need a 90wt oil with positrac additive inthe rear.
I learnt this the hard way :sad:
Old Jun 20, 2003 | 04:48 PM
NSTG8R's Avatar
NSTG8R
Could be worse, the dealer could go tell you to pound rice.
Old Jun 20, 2003 | 04:54 PM
Quick Brick's Avatar
Quick Brick
Default Re: Differential failure due to wrong oil! (Neablas)
I have used Mobil1 85-90 rear end oil with good results. Most synthetics require little or no friction additive.
Old Jun 20, 2003 | 05:11 PM
6SPD98's Avatar
6SPD98
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18- '19
GM Synchromesh is used in the transmission, not in the rear. You're lucky the dealer is taking responsibility for this disaster. Best of luck
Old Jun 20, 2003 | 05:29 PM
:eek: What a disaster. Glad the dealer is taking care of the mistake.
Old Jun 20, 2003 | 08:19 PM
ElanMike's Avatar
ElanMike
Just to update. Cartek is overnighting the parts to the dealer. they will get on fixing ht issue right away and will have the car for me early next week. It's nice to find a dealer who will stand behind their actions, even when it costs them over $600 and 2 days of labor. :yesnod:
Old Jun 21, 2003 | 01:22 AM
FunDriver's Avatar
FunDriver
Veteran: Marine Corps
That's great. Who was the dealer down there? It's a bit far for me and my dealer is ok, but it's always nice to know of another good dealer around.
Old Jun 21, 2003 | 10:30 AM
jimman's Avatar
jimman
Default Re: Differential failure due to wrong oil! (MANNY)
Confused, doesn't the owners manual tell you what to use? I would think that the shop that put it in would know a bit more than that. :confused:
To Differential failure due to wrong oil!
