Are Right and Left Tires Interchangeable
Old Jun 20, 2003 | 07:38 PM
knesbitt's Avatar
knesbitt
Default Are Right and Left Tires Interchangeable
Are Right and Left Tires Interchangeable? I need to know before I take the wrong spare tire to shop to get mounted.
Old Jun 20, 2003 | 09:07 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Default Re: Are Right and Left Tires Interchangeable (knesbitt)
If your talking about stock Goodyear EMT's then the answer is no, if your talking about any other tire then just look at the sidewall if there is an arrow showing the rotation direction then you can't put that on the other side of the car because obviously it would be turning the wrong direction.
Old Jun 20, 2003 | 10:48 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Default Re: Are Right and Left Tires Interchangeable (runamuk)
If your talking about Goodyear EMT's the answer is yes.. Not no... the tires are directional.. but you can but them on either side as long as the directional arrow is in the right place.... Yo can NOT however take a mounted tire from the right side and put it on the left side... you can take an unmounted tire and mount it on either side..
Old Jun 21, 2003 | 12:35 AM
knesbitt's Avatar
knesbitt
Default Re: Are Right and Left Tires Interchangeable (Evil-Twin)
The tires I hav are used from another forum member. How do I know which side the tire was mounted on?
Old Jun 21, 2003 | 12:44 AM
RUGBY's Avatar
RUGBY
:withstupid:
Old Jun 21, 2003 | 12:48 AM
wkasak_07Z06's Avatar
wkasak_07Z06
:iagree:
The tires can be swapped side to side, but will need to be dismounted from the rims, and remounted so that the arrow is facing forward on the respective side. :cheers:
[Modified by wkasak_98Coupe, 12:51 AM 6/21/2003]
Old Jun 21, 2003 | 12:52 AM
wkasak_07Z06
Unless he marked them before they were dismounted, you probably won't be able to tell...Only way I can think of is look for tire dressing, or scuffs that would indicate the side facing out when they were original mounted.
Good luck.
[Modified by wkasak_98Coupe, 12:54 AM 6/21/2003]
Old Jun 21, 2003 | 12:55 AM
knesbitt's Avatar
knesbitt
Default Re: Are Right and Left Tires Interchangeable (wkasak_98Coupe)
Great. So either unmounted tire can go on the left or right side. The rim is the only part that cannot be swapped from side to side? Am I correct about the rim?
Old Jun 21, 2003 | 01:05 AM
knesbitt's Avatar
knesbitt
What happens if the previous owner had Tire 1 on the left side and I take that same tire and mount it on the right side?
Old Jun 21, 2003 | 01:51 AM
Evil-Twin's Avatar
Evil-Twin
Nothing...
Old Jun 21, 2003 | 06:04 AM
BQuicksilver's Avatar
BQuicksilver
Cruise-In III Veteran
Cruise-In IV Veteran
The rims can also be swapped...you just can't swap a rim WITH tire mounted, because that would change the direction of the tire's rotation. If you want to take the tire off the rim and re-mount it the right way then that would be okay.
Of course you can't swap front tires or rims with rear because they are just different sizes...before anyone asks.
Old Jun 21, 2003 | 10:06 AM
wkasak_07Z06
Default Re: Are Right and Left Tires Interchangeable (BQuicksilver)
:iagree:
Old Jun 21, 2003 | 10:08 AM
knesbitt's Avatar
knesbitt
Old Jun 21, 2003 | 11:06 AM
gpflepsen's Avatar
gpflepsen
Cruise-In II Veteran
Where do you get this from?
You can put the GY EMTs on either the left or right. The only concern is the direction or rotation. This tire is symetrical and directional. Symetric means there isn't an inside or outside to the tread design and directional means it is designed to roll in a certain direction.
To "rotate" the EMTs you need to dismount them and flip them on the rims. Because of the pressure sensors it's just as easy to swap rims and tires.
Old Jun 21, 2003 | 11:23 AM
Richin Chicago's Avatar
Richin Chicago
I think you are confusing the EMTs with the asymmetrical tire that is stock on the Z06. As long as the tire has a symmetrical tread (the EMTS and most modern tires using tread block do) you can mount them on either side. Of course you would have to take them off the rim. A good way to check a tire to see if it is asymmetrical is to see if it has separate part numbers for right and left side.
Old Jun 21, 2003 | 11:27 AM
gpflepsen's Avatar
gpflepsen
Default Re: Are Right and Left Tires Interchangeable (Richin Chicago)
Aren't the Supercar tires non-directional? That would make them applicable to either left or right side use too.
Old Jun 21, 2003 | 11:45 AM
Richin Chicago
Default Re: Are Right and Left Tires Interchangeable (gpflepsen)
No I am confused! This is from the Tirerack site on the Z06 tire:
"Since each of these vehicles uses different front and rear tire sizes, they all require four separate “corner specific” tires"
To Are Right and Left Tires Interchangeable
Old Jun 21, 2003 | 11:57 AM
gpflepsen's Avatar
gpflepsen
I find this on this page:
"The tires for McLaren and Ferrari vehicles feature very large tread blocks formed into asymmetric and directional tread designs. Since each of these vehicles uses different front and rear tire sizes, they all require four separate “corner specific” tires."
Look on the size and pricing page and the non-corvette sized are denoted as left/right specific.
I take this as the Mclaren and Ferrari sizes are directional while Corvette isn't.
I suppose if I had a Z I'd know for sure.
Old Jun 21, 2003 | 12:46 PM
Oldvetter's Avatar
Oldvetter
Be aware IF you switch rims (with tires demounted) nfrom one side to another, you will have to relearn the tire air pressure sensors with a magnet or else they will indicate the wrong side.
[Modified by Oldvetter, 12:47 PM 6/21/2003]
Old Jun 22, 2003 | 10:41 AM
jim2527's Avatar
jim2527
Default Re: Are Right and Left Tires Interchangeable (Oldvetter)
Smething to aware of is the difference between asymetrical and directional tires. Directional tires must rotate in one direction. Asymetrical tires have different patterns on the outer and inner tread surfaces. Some tires are marked 'inside' and 'outside' regardless of being directional or asymetrical.
A non-directional, asymetric tire (Z06??) can be rotated left to right without dismounting from the rim.
A directional, asymetric tire can only be rotated front to back if they are the same size (C4verts??). If the fronts and rears are different sizes (later C4's) you have 4 corner specific tires.
Remember about the tire pressure sensors ans noted above....
