All Stroke and NO Bore???
Old Jun 21, 2003 | 10:56 PM
SvenOdin's Avatar
SvenOdin
Default All Stroke and NO Bore???
As some of you are aware, I've been contemplating going the stroker route instead of FI.
I recently heard about some people doing an all stroke and no bore on their LS1. Basically, if I have this right, you keep your LS1 engine and just install a Lunati stroker crank (4.00 - 4.125), Lunati Pro Billet rods Diamond pistons and rings and without boring or buying a resleeved LS1 block you have now increased displacement to 396ci..... Is this right??:confused:
I'm a complete noob to all this, but the impression I have is that this procedure is basically forging the bottom end, and gaining a little more displacement via stroker crank. Is this feasable? Would there be any reliability/longevity issues with just increasing the displacement without bore??
If there is no downside to this, I may consider it as it's much cheaper than going the resleeved block route!
Old Jun 22, 2003 | 01:20 AM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: All Stroke and NO Bore??? (SvenOdin)
with the all stroke kit, you can only goto to 382.
Old Jun 22, 2003 | 01:45 AM
kumar75150's Avatar
kumar75150
Default Re: All Stroke and NO Bore??? (ICULUKN-C5)
Nope Lunati also has the 4.125 crank with which you can get 395ish cubic inches.
Old Jun 22, 2003 | 02:14 AM
mapman's Avatar
mapman
Stroker motors are going to have higher piston speeds, this may generate more heat and limit rpm (component failure).
How does the HP/torque characteristics of this combination match your intended use of the car?
Old Jun 22, 2003 | 03:28 AM
Mitch C's Avatar
Mitch C
Default Re: All Stroke and NO Bore??? (kumar75150)
:iagree:
Old Jun 22, 2003 | 07:05 AM
Eric Fischer's Avatar
Eric Fischer
People have been stroking engines for years. The cons are few; as mentioned the piston speeds are greater, and for extreme strokers oil control issues can surface because of the very short ring package on the piston (although this is very rare).
In terms of the LS1, neither strokering or large boring the motor is cheap. A stroker rotating assemble is around $3500 for parts alone. A large bore motor with new pistons will run about $3100 for the block and pistons. Then add assembly for both and installation and it adds up real quick.
Depends on what your goals are, but when you have guys in tbe 10's with the stock block, and H/C/I it doesn't make much financial sense to go stroker or large bore (unless you want to be different)
Old Jun 22, 2003 | 09:27 AM
FreddyG's Avatar
FreddyG
If you're on a tight budget, there are places that will make an offset ground crank (budget stroker). The LS1 cranks will take a good amount of power before taking a dump.
Old Jun 22, 2003 | 12:12 PM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
downsides to a stroker motor over a bore motor, are increased sideloading, more weight being thrown, faster piston speeds, and dead time at top and bottom end of the stroke.
with a stroker you get the automatic increase in HP because of displacement, but stroke over bore is more suited to doing a lot of work over a lot of time (ie stump pulling, trailer towing etc... where you do work down low in the rpm range).
With bore over stroke, you get better flow, quicker revving, more HP, better durability. Much more suited to racing.
Either choice you make will be an improvement tho.
[Modified by kewlbrz, 11:13 AM 6/22/2003]
Old Jun 22, 2003 | 02:13 PM
kumar75150's Avatar
kumar75150
Default Re: All Stroke and NO Bore??? (kewlbrz)
Only problem with bore motors is that there are still leaking issues with most vendors. Just make sure you get a long warranty.
Old Jun 22, 2003 | 03:02 PM
Eric Fischer
What kind of leaks? (just curious)
Old Jun 22, 2003 | 11:29 PM
kewlbrz's Avatar
kewlbrz
its been my understanding vendors like MTI, ARE, LPE, Cartek, etc... solved the leaking problem ages ago. Are you referring to something more recent or specific?
Plus there is the 4.125 C5-R block and the darton sleeved blocks offered by lingenfelter, cartek , and others.
Old Jun 23, 2003 | 01:11 AM
kumar75150's Avatar
kumar75150
From the research I have done, about 3 years ago 5/10 bored motors leaked. Now that number has been reduced to about 1/10. Thats still a pretty high percentage.
Personally I know that bore motors make more power than all stroke ones but I just didnt feel too comfortable. Also, you have to decided how much bottle you want to throw at the motor.
Old Jun 23, 2003 | 07:15 AM
MattG's Avatar
MattG
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
It has been probably two years or more since I have heard of ANY sleeve problems with ARE's resleeved blocks. In the early stages of the resleeve development they had their issues here and there but they always fixed it up for the customer.
I know I personally have put over 20K miles on an ARE resleeved block without any problems.
Old Jun 23, 2003 | 12:00 PM
C5-VERT's Avatar
C5-VERT
Cruise-In IV Veteran
Default Re: All Stroke and NO Bore??? (MattG)
:withstupid:
I have had an MMS built 388 All-Bore motor for a year and no problems at all. I am pretty sure the old sleeving process has been fixed.
:seeya MattG
[Modified by C5-VERT, 12:00 PM 6/23/2003]
Old Jun 23, 2003 | 06:05 PM
SvenOdin's Avatar
SvenOdin
Default Re: All Stroke and NO Bore??? (C5-VERT)
Thanks for the info. I think I'll just wait and do it right :reddevil
To All Stroke and NO Bore???
