TPIS Long Tube and Random Tech Install (Some notes from Todays Install)
A couple of things we had to do to get them in there.
Drivers side:
Besides removing the alternator, steering linkage, coil packs, and Air Tubing, we also pulled the valve cover and the oil filter. Once we did the above, that puppy slid right in there.
Passenger side:
The thing that was hanging us up was the tranny cooling lines at the base of the torque tube (A4). Once I undid the bracket holding the lines and pulled them down out of the way, with a little prying on the header, she came down and popped into place.
For the tabs that mount near the old cats, they were about 1/4 to 3/8" off from the holes, both sides. One quick whack with a 5lb hammer on the mounting bracket (it bent easily) and the holes lined right up. :smash: :smash:
The cats slide right into the TPISLT's so after using some sandaper to smooth the inside the cats slid in and then I just gave them each a few whacks with a piece of wood on the end and knocked them into place.
The Random Tec x-pipe also is a slip fit but it was a little looser then I wanted. I gave it one wrap around with some aluminum exhaust tape (it's very thin) and then pushed the x-pipe into place. It toook a little pulling on the driver side cat to get them to line up as the header did not exit perfectly straight out the back. But it wasn't much of a pull to get it into place.
The x-pipe then bolted right up to the Corsa's that were already installed. I did have to use 7/16" bolts with nuts and lock washers as the Corsa's only needed a bolt to the stock x-pipe, but that was easy enough.
So, after slappin' it back together, she rocks and sounds great. It was funny because on the commute to work the other day I was reading the new Corvette Fever and they did the same install and did before and after Dyno's showing an increase of 40rwhp with the complete same setup. I'll believe that when I see it. I took mine to the Dyno a few weeks ago for a baseline. I have a little more work to do and then I'll be back to see (and hope for) what the overall gains are.
:auto: :auto: :auto:
[Modified by 78Vette-SA, 7:30 PM 6/22/2003]
I have a leak where my RandomTech cats slide into the collectors of my Stainless Works LTs.
WHERE did you get this "aluminum exhaust tape"???
thanks
:cheers:
[Modified by SideStep, 3:07 PM 6/23/2003]
What I really would like to see is flanges welded on the ends of the headers and on the inlet of the RT cats. This would practically eliminate any leaks and make a much simpler and easier install.
Joe, this weekend, I had the Vette up on the lift and noticed on my TPIS headers (I did not install them) that one of the cooler lines runs right up next to the header pipe, almost looks like it touches it. This cannot be good over the long run. Is this the way yours ended up? I sure would like more room there.
:cheers:
How is the aluminum exhaust tape doing?? Any leaks???
thanks
:cheers:
