Resonance problems
Old Jun 24, 2003 | 11:44 AM
Face's Avatar
Face
Default Re: Resonance problems (Cary)
Hey Face, what rear gears do you have? A4 (2.73 or 3.15 or 3.42) or M6 (3.42 or taller)
A4 with 3.73's and a SY3500 converter. On the parkway I'm fine since I usually travel at 60-70, but in slower traffic and main roads the drone can be very annoying.
:eek: A4 w/3.73 Wow, no wonder you have a drone. Please don't get me wrong, I know your C5 is badass on the 1/4 track. If I'm at 2200rpms at 70 mph in my A4 w/3.42 rear I wonder what your tach reads at 70 mph w/3.73?
I suppose the SY3500 has nothing to do with your drone? Maybe mine will have a less drone since my gears are not as tall as yours? I hope :confused: Or, do I have it backwards. Its the slower speed that feels the drone :mad :confused: really confused now.
[Modified by Cary, 9:57 PM 6/23/2003]
It's backwards. When I had 3.15's, the drone was worse, and I had to apply more pedal to get out of it. With the 3.73's it feels as the range of rpms the drone occurs and the amount of pedal I need to apply to get out of the drone both decreased. If I were to do it over again I would have gone with 3.90's. :D
Old Jun 24, 2003 | 11:56 AM
Richin Chicago's Avatar
Richin Chicago
Default Re: Resonance problems (Face)
[Modified by Cary, 9:57 PM 6/23/2003]It's backwards. When I had 3.15's, the drone was worse, and I had to apply more pedal to get out of it. With the 3.73's it feels as the range of rpms the drone occurs and the amount of pedal I need to apply to get out of the drone both decreased. If I were to do it over again I would have gone with 3.90's. :D
AFAIK and what the Corsa people told me and the TSB all indicates the worst of the resonance zone is at 1500 RPM. Anything above or below that is better.
Old Jun 24, 2003 | 10:26 PM
Cary's Avatar
Cary
Default Re: Resonance problems (Fast one)
I bought two Car Chemistry header inserts for the exhaust pipes that are supposed to reduce resonance; these could be the cure for the stinger drone. If they work I'll let you know.
I sure would like more info :yesnod:
Old Jun 25, 2003 | 12:56 PM
Fast one's Avatar
Fast one
Installed them last night and removed the inserts borla sent me last year; it took four hours since the whole system had to be dropped. The new inserts cut the resonance down a lot but not entirely, about 60-70%. I didn't have an industrial laser handy to put holes in the stock pipes for stainless steel pop rivets so they were tapped in right at the joint to the x-pipe. The two trailing rings of the inserts that fit into the x-pipe were ground slighty for an easy fit. For systems with no x-pipe the inserts should fit into the exit of the h-pipe, a lot less work. The Jegs part # is 176-3D135L which is a 3 disk 2 1/2" insert, two are needed.
Old Jun 25, 2003 | 01:24 PM
gmf's Avatar
gmf
One thing to consider, dunno. SLP sells an XPIPE with built-in resonator. I added this to my SLP Loud mouth and WOW what a difference. My resonance is in the 2200-2500 RPM range on my A4 and this occurs only under very light acceleration/gas (like when going up a hill with cruise control at 75mph).
I have 3.15's so my cruising RPM's are 1800-2400.
It still has a mild resonance, but if I can stop the SLP resonance, the stingers
should be a piece of cake with the SLP xpipe w/ resontaor.
Another thing I notice that helps, for you coupe guys - don't use your glass top. The painted top seems to absorb some of the resonance bouncing around in the car.
I really have 0 resonance with windows down and/or top off on my coupe. I don't know many loudmouth people who can say that with no xpipe w/ resonator. I highly recommend it.
Just my $0.02!
[Modified by gmf, 1:27 PM 6/25/2003]
Old Jun 25, 2003 | 01:47 PM
gmf's Avatar
gmf
Default Re: Resonance problems (gmf)
another source of help for you resonance and interior noise level is:
http://www.b-quiet.com/
I have thought of using them, but have not, yet...
:cheers: :seeya
Old Jun 25, 2003 | 02:22 PM
jimman's Avatar
jimman
If the resonant sound was high frequency it would be easy. The low frequency stuff we have here is a problem. Unfortunately Lead is the most effective do to it's density but weight will kill you. I had a jet boat with a 455 Olds engine and lead was all that would work.
Old Jun 25, 2003 | 02:33 PM
Cary's Avatar
Cary
THANKS :thumbs:
:cheers: Cary
