Manual High speed fan switch
Is there a way to setup a manual fan switch that will turn the fans on in high speed mode without causing problems for the normal PCM controlled mode?
I know they can be programmed and have done this, but I want a manual switch for certain situations (like in the staging lanes) and don't want to reflash the PCM every time I want the fans on earlier.
I found this schematic if someone would like to reference it in an explanation.
http://www.vetteguru.com/misc/fans.gif
Any help would be greatly appreciated.
[Modified by QuickSilver2002, 10:41 PM 6/23/2003]
anybody who wants the manual fan switch instructions email me at intel55@aol.com and you shall have this $10 (in parts)mod
:D :D :cheers: :smash:
OH yeah MAKE SURE YOU PUT IN THE SUBJECT LINE: FAN MOD!!!!!
thanks :D
[Modified by intel55, 2:13 AM 6/24/2003]
I'm a little confused about how the mod in the email works. Does it allow you to keep the PCM controlling the fans when the switch is not on?
I'm not an EE of any sort, but it looks like there would be a pretty simple way to accomplish what I want (now that I have studied the schematic for quite a while).
It appears that all three relays (coolfan1,coolfan2,coolfan3) need to be activated for the fans to be in high speed mode (both wired to a 12v source). In low speed mode, coolfan 1 is activated and the fans are both on, but wired in series. The pcm grounds both the low and high speed wires to accomplish high speed mode. The low wire activates coolfan1 while the high speed wire activates coolfan2 and coolfan3.
I think it would be pretty simple to find the fan control wires coming from the PCM (DK GRN-42 and DK BLUE-33) and setup 2 little relays to ground them when a manual switch is on.
I can't see how this would cause any problems, but I'll run it by an EE friend of mine just to make sure before I try it. I'll post pics and instructions when done.
[Modified by QuickSilver2002, 12:31 AM 6/25/2003]
I have a slightly different purpose. I have my intercooler mounted directly in front of the radiator and I want to pull as much air as possible across it and drop the coolant temp down as much as possible before I hit the tree. I'm also going to rig up something that will spray the intercooler with a fine mist.
I'll keep you guys posted on how my fan switch mod works out.
It was so simple that I can't believe more people have not done it.
I'll probably do a more complete write-up with pics later in the week, but here are the basic instructions.
Look at this schematic http://www.vetteguru.com/misc/fans.gif
Look at the bottom left of the diagram where it has the dashed line around the PCM and the two wires (DK green and DK blue) labeled. You will basically be splicing into these wires and adding in a manual switch that runs each wire to ground. Grounding the green wire only will turn both fans on in low speed mode (wired in serial). Grounding the blue wire will turn the right fan on in high speed mode. Grounding both wires will turn on both fans in high speed mode. The ignition has to be on for the blue wire to have any impact, but the low speed fans can run without the ignition in the on position.
Here are the basic instructions
1. Take off the front passenger wheel and wheel well panel that protects the PCM.
2. Crawl under the car and you will see two long connectors that are bolted up to the PCM. Unbolt both connectors and pull them away from the PCM. You will see that one is blue and one is red (on the inside).
3. Page 6-618 of the 2002 manual has the pin outs for these connectors labeled in detail. On the Blue connector you are looking for pin 42 which is the dark green wire (low speed). It is the 2nd pin from the left on the top row with the tabs on the connector oriented upward. The wire is somewhat hard to get to (since it comes from the end of the connector and not from up top) and you will probably have to cut away some of the shielding tape to see it. The space is tight, but it is not bad if you use a tap connector to splice into it (they sell these at Home Depot - look for something close to 30 AWG). I think there was another dk green wire on this connector, so make sure you get the right one.
4. The Red connector contains the high speed wire (dk blue). It is pin 33 and is on the bottom row 8th from the left with the tabs facing up. It is also a little hard to get to for the same reasons, but I think there is only one wire this color to worry about.
5. After you have spliced into these wires you can do whatever you would like to setup a switch that will ground them. I ended up using two relays and some lighted switches mounted in my ash tray area, but you could go as simple as some alligator clips in the batt box. Pretty much anything would work and there are several different ways to do it. Just remember you don't want to switch them to a power (+) source. You are simply switching them to ground (-).
[Modified by QuickSilver2002, 10:19 AM 7/2/2003]
This does cause p0480 and p0481 (fan relay circut) to get thrown when the PCM tries to turn the fans on (but they are already manually overidden). This is a rare situation, but it can happen. These can be easily disabled in ls1edit to keep the check engine light off. Other than the light coming on, it seems to cause no harm.
Would installing a few diodes help stop the manual ground signal from getting back to the PCM?
If you use a relay similar to the stock relay #44 (a two output relay) between the power wire to the fan motor and the fan motor itself then when the manual fan switch is off the PCM would control the fan and when the switch is on the fan motor would be on regardless of what the PCM wants to do.
As the stock relays would continue to function as commanded by the PCM, no codes would be thrown :cheers:
[Modified by SFVetteman, 10:08 PM 7/4/2003]
---Manny
According to the diagram referenced in the original post the left fan is controlled by the #45 relay. Moreover, the fans are not grounded by the relays they are powered by them. The other terminal of the fan motor goes to ground. Most importantly, my method bypasses the stock relays and PCM when you want high-speed operation of one or alternatively both fans without the PCM throwing codes.
Let me try to explain this a little differently so you can understand.
1) You will need a new relay similar in design to the #44 relay, toggle switch, some wire and an inline 30-amp fuse. 2) Remove the blue 409 wire from the left fan motor. 3) Connect the unswitched side of the new relay to the left fan motor. 4) Connect the switched, normally open terminal of the new relay to a new wire with a 30-amp fuse going to the battery or other 12-volt source. 5) Connect the other switched normally closed terminal to the blue 409 wire. 6) Connect a wire from one of the relay coil terminals to the wire going to the battery or other 12-volt source. 7) Connect a wire from the other terminal of the new relay coil to one terminal of a dash-mounted switch. 8) Connect a wire from the other terminal of the dash-mounted switch to ground.
Now with the flip of a switch you have a choice of normal fan operation using the stock relays and PCM or manual high-speed operation of the left fan motor with no codes. The procedure for the right fan motor is the same except that the white 504 wire instead of the blue 409 wire controls the right fan motor. If you want to have the ability for both fans to run manually at high-speed, you will need one new relay for each fan.
