For all your Hurst owners
Old Jun 24, 2003 | 11:21 AM
BHulsey's Avatar
BHulsey
Default [Poll]For all you Hurst owners
Just wanted to know. :cheers:
[Modified by BHulsey, 4:23 PM 6/24/2003]
[Modified by BHulsey, 10:29 PM 6/24/2003]
Old Jun 24, 2003 | 11:23 AM
Patches's Avatar
Patches
Default Re: For all your Hurst owners (BHulsey)
Stops are only recommended for hard-shifting in race situations. T56 has it's own built-in stops.
Old Jun 24, 2003 | 04:06 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Default Re: [Poll]For all you Hurst owners (BHulsey)
I couldn't tell a difference when installing the shifter, so I loctited and adjusted them per the Hurst instructions. I realize they aren't needed, but don't see the reason for taking the stops out either.
:cheers:
Old Jun 24, 2003 | 05:22 PM
AFVETTE's Avatar
AFVETTE
Stops are not needed and could work there way off and jam. Just made sense to me not to install them. BTW I sent Hurst an e-mail and that was their reply.
Tom
USAF Retired
Old Jun 24, 2003 | 07:58 PM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
I left mine in, I just installed them properly. :D (There really haven't been that many that came loose and the ones that did, the guys said never put lock tite on them.) I have had almost 1 1/2 years of serious banging shifts:steering: , no problems. :smash: :smash: :cheers:
Old Jun 25, 2003 | 09:32 AM
ZO6-2003's Avatar
ZO6-2003
Default Re: [Poll]For all you Hurst owners (racer44)
I Just installed my Hurst last week. Love the shifter and I installed it without the stops and put a rubber boot over it to help decrease noise. Now, I just need to get rid of the buzz sound at around 3.5K RPM and I will be a happy camper! :D
Old Jun 25, 2003 | 01:53 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Default Re: [Poll]For all you Hurst owners (Y2Kvert4me)
:iagree:
Old Jun 25, 2003 | 02:20 PM
DS's Avatar
DS
I just got a Hurst myself and was wondering about the same thing. I don't think I will install it with the stops in.
Old Jun 25, 2003 | 06:21 PM
BHulsey's Avatar
BHulsey
I just reinstalled mine last night without the stops. Full day driving, and it feels great. Reverse is easier to get into also. :cheers:
Old Jun 26, 2003 | 02:29 AM
MagRed2002's Avatar
MagRed2002
Hey Z06-2003 -
There have been lots of posts here regarding eliminating the vibration on the aftermarket poopieers. I have the Hurst, and personally I have never had a vibration problem. However, if you do it is a vibration frequency problem. Most here have changed shift ***** and eliminated the issue. If you like your current setup and dont want to change, try attaching wheel weights or some other relatively massive object to the shaft under the boot. That will alter the vibration characteristics of the shifter assembly in most cases and eliminate the noise.
Some may back me up on this issue - If not, do a search.
Old Jun 26, 2003 | 07:50 AM
ZO6-2003's Avatar
ZO6-2003
Default Re: [Poll]For all you Hurst owners (MagRed2002)
Thanks Magred2002
Yes believe me I have read just about all the threads on both sites. I'm currently using a MGW shifter **** and last night I installed the wheel weights. The weights helped a little but I'm still getting the buzz at around 3K Rpm. Note: this is a buzz noise, and not some vibration that I can physically feel.
Darn, I guess I will have to get the Borla Stingers :rolleyes: to really cover up the noise!! :D :D
Old Jun 26, 2003 | 09:41 AM
John's vette's Avatar
John's vette
Cruise-In IV Veteran
Without.. I had both back out and lock out my gears. One the first week and the other about 9 months later. I removed both now.
Old Jun 28, 2003 | 01:46 AM
dfwroadkill's Avatar
dfwroadkill
St. Jude Donor '07-'09
I took my stops out last night. Mine rattled too much for me. I like the shift, but not the noise. After I took the stops out, I went for a spin with no shift **** on. It seemed that the noise was down about 85% - 90%. Maybe it's in my head, but the shifter seems a little better, more loose. Reverse seems easier. I reattached the shift **** (factory) and got it super tight with teflon tape on the threads. It's much quieter, but did add some of the rattle back in. I have a **** on order. :-( Now if the dang thing will just ever get here.....
Old Jun 28, 2003 | 04:03 PM
88sk's Avatar
88sk
Default Re: [Poll]For all you Hurst owners (dfwroadkill)
alot vibe problems are related because of play between the threads of the shifter& ****,try wrappin teflon tape around the shifter threads to get rid of the loose fit that should take care of it ,had my hurst w/ stops on for a month& no problems :chevy
Old Jun 29, 2003 | 08:51 AM
Highroller's Avatar
Highroller
Default Re: [Poll]For all you Hurst owners (88sk)
No stops, lite springs, stock ****, no noise, I lucked out :thumbs:
Old Jun 29, 2003 | 10:46 PM
Joecooool's Avatar
Joecooool
Jax Events Coordinator
CI 3-4-5-6-7-8-9 Veteran
St. Jude Donor '03-'08
:cheers:
:withstupid:
To For all your Hurst owners
