I am in need of some info on my seat adjust...PLEASE.
I use the auto out option when shutting down the car. This morning I mistakenly placed my Z71 key in the ignition and now I have no power to the drivers seat. I see in the manual there is a fuse on the inside compartment and it is good. I also see there is a so called circut breaker in the engine compartment. Is there a way to tests this circut breaker or reset it.
Or does anyone have any suggestions as to what happened?
It's a long way to bottom out the clutch in the easy out possition, if anyone can help it would be greatly appritiated. I have a '99. :banghead:
Just figured out what DIC was "Drivers Information Center" went to check and all works. The circut breaker must have reset.
Thanks for the help topless. :party:
