Breathless Performance Shifter.... Anybody?
Old Jun 26, 2003 | 01:14 PM
LANZ06's Avatar
LANZ06
Default Breathless Performance Shifter.... Anybody?
I am considering getting this shifter. I really like the fact that you can adjust where the shifter will be. I need it to be an inch or two forward. Anyone have one or know of someone with it.
Old Jun 26, 2003 | 01:37 PM
Red C5's Avatar
Red C5
Default Re: Breathless Performance Shifter.... Anybody? (LANZ06)
I have one. It's not bad. The shifts are still too long IMO. :cheers:
Old Jun 26, 2003 | 02:54 PM
cfi_luz's Avatar
cfi_luz
Default Re: Breathless Performance Shifter.... Anybody? (Red C5)
I have one as well, what exactly were you wondering other than can it be adjusted 1 or 2" forward (which it can)?
Old Jun 26, 2003 | 02:58 PM
LANZ06's Avatar
LANZ06
Default Re: Breathless Performance Shifter.... Anybody? (cfi_luz)
Are you happy with it. Is it a big difference over stock as far as feel and throw?
Old Jun 26, 2003 | 03:04 PM
Patches's Avatar
Patches
http://www.z06vette.com/reviews.php?prodid=7
A link to a review.
Old Jun 26, 2003 | 03:23 PM
cfi_luz's Avatar
cfi_luz
Default Re: Breathless Performance Shifter.... Anybody? (Patches)
I am personally very happy with it. I think the throws are fairly short and very accurate. It took a little time to get used to, slightly notchy but not bad. Mine does rattle a little bit with the hardbar shift ****, but nothing unbearable.
Old Jun 26, 2003 | 03:59 PM
allanlaw's Avatar
allanlaw
It's really a matter of personal taste. If you want to move the shift position back (away from the dashboard), the BPP will give you a lot of options. There is not much room for a forward move, especially with a long **** like the Hardbar. I tried to use the angled forward setting with BPP's standard shaft and did not have enough clearance with the temp **** on the dash to shift with my racing gloves on. I don't know if the angled shaft would work better for a forward move. I found the lateral spring load to be very strong, even with the lightest supplied springs, and I was used to using a Ripper. However, the springs are very easy to switch, and I am currently experimenting with some springs I picked up at the hardware store (and cut to fit) with a lighter load. The BPP is very quiet compared to the way my Ripper was before I added weights to the shaft. However, all in all, I would give the Ripper the nod. I may change my mind after more experience with the BPP and maybe another change or two in the spring load.
Old Jun 26, 2003 | 04:35 PM
LANZ06's Avatar
LANZ06
Thanks guys
Old Jun 26, 2003 | 05:09 PM
ryan0's Avatar
ryan0
is the bpp shifter any shorter?.. like the length over the stock shifter.. my **** sits way too high... it looks like its out of a VW bus.. heh.
Old Jun 27, 2003 | 11:04 AM
C54FUN's Avatar
C54FUN
St. Jude Donor '03-'05-'06-'08-'10
Default Re: Breathless Performance Shifter.... Anybody? (ryan0)
Guys, am getting ready to install my BPP shifter and had a question; in addition to the angled spacer there is another reddish-brown spacer of sorts with holes that align with those of the shifter handle; anybody know where this goes? Could it be this is installed to reduce vibration coming up the shifter? Appreciate your responses and thanks.
Joe
Old Jun 27, 2003 | 11:47 AM
CSC5's Avatar
CSC5
From: Yeah, well, you know, that's just, like, your opinion, man.
Default Re: Breathless Performance Shifter.... Anybody? (C54FUN)
Joe
I think that's to reduce vibration. They didn't come with the shifter when I ordered mine, but I got one later. I'm not 100% sure where to put it, so I've left it off for now.
Overall, I'm very happy with the shifter. It's position is perfect, and I find the throws to be short and crisp. It does take some getting used to, however.
Old Jun 27, 2003 | 04:46 PM
LANZ06's Avatar
LANZ06
It should be wedge shaped. If it is, its so you can angle the shifter either towards you or away from you.
To Breathless Performance Shifter.... Anybody?
