Tranny Cooler or Trans shift kit???
Old Jun 26, 2003 | 10:54 PM
thefly's Avatar
thefly
Default Tranny Cooler or Trans shift kit???
we installed a pt2400 stall and a 3.42 rear end. and it was suggested that due to the extra slippage from the higher stall that the tranny will heat up more, and should consider installing a tranny cooler. so of all you A4 guys what route do i need to go? i know everyone says the shift kit is a must mod, however the main concern is to protect the life of tranny, which will protect it better, and do i need one at all. the car is a daily driver, seeing autocrosses 3-5 times a year, 1 driver education / road race event, and 3 trips to the dragstrip.
Old Jun 26, 2003 | 11:13 PM
clancy's Avatar
clancy
Default Re: Tranny Cooler or Trans shift kit??? (thefly)
Tranny cooler first, It cost less & will do more to protect your trans., Just my .02 You can always do the shift kit at a later date. :cheers:
Old Jun 27, 2003 | 12:14 AM
ROD BROWN's Avatar
ROD BROWN
I would definitely try to do both.I know its expensive,but in my opinion,they are both a must. :chevy :chevy :flag :flag :chevy :chevy
Old Jun 27, 2003 | 08:25 AM
RWhite's Avatar
RWhite
Default Re: Tranny Cooler or Trans shift kit??? (ROD BROWN)
Heat kills tranny's. A cooler is cheap insurance and easy to install. Pep Boy's has all you need or you can go more expensive routes. They all do the same thing. I have done a bunch of them over the years and have had no problems with leaks, etc.
Old Jun 27, 2003 | 09:28 AM
BayouVette's Avatar
BayouVette
Default Re: Tranny Cooler or Trans shift kit??? (RWhite)
I'm in the process of doing both right now. I just recieved my shift kit yesterday and ordering my B&M tranny cooler on tuesday.
To Tranny Cooler or Trans shift kit???
