Rear Brake Cooling Ducts
Old Jun 26, 2003 | 10:57 PM
detsgt696's Avatar
detsgt696
Default Rear Brake Cooling Ducts
What is the best tool to cut the body to install the ZO6 style cooling ducts?
Old Jun 27, 2003 | 06:01 AM
AZ Curmudgeon's Avatar
AZ Curmudgeon
Default Re: Rear Brake Cooling Ducts (detsgt696)
I used a Dremel with a cutoff wheel.It cut through it like butter and was easy to control.
Old Jun 27, 2003 | 06:38 AM
detsgt696's Avatar
detsgt696
Thanks for the tip.I'll try it.
Old Jun 27, 2003 | 11:53 AM
TIKTGTR's Avatar
TIKTGTR
Measure twice and cut once!! I thought I was gonna :U when I started cutting the first side. Good luck and post some pics when its all done :cheers:
Old Jun 27, 2003 | 10:46 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
I used a hand help little sabre saw ( skill saw )... like the one used to cut paneling. the cut was so clean I couldactually put these panels back if I had too
Old Jun 27, 2003 | 11:08 PM
Skyguy^^'s Avatar
Skyguy^^
I used a spiral saw, however you may want to check out this: http://forums.corvetteforum.com/zerothread?id=588723 :cheers:
Old Jun 28, 2003 | 01:48 AM
Izover4u's Avatar
Izover4u
I used a roto zip... real easy to follow the lines of the template... :cheers: :cheers:
Old Jun 28, 2003 | 09:10 AM
kvozel's Avatar
kvozel
From: Centerville OH "If we weren't all crazy we would go insane"
CI 3-4-5-6-7 & 9 Veteran
St. Jude Donor '08
What about the holes for the screws to hold the ducts in place? I assume just a normal drill? What size?
Old Jun 28, 2003 | 03:45 PM
Izover4u's Avatar
Izover4u
Default Re: Rear Brake Cooling Ducts (kvozel)
yup... use a normal drill... i used 7/16 bit...
Hope this helps... :cheers:
Old Jun 28, 2003 | 05:24 PM
kvozel's Avatar
kvozel
St. Jude Donor '08
Default Re: Rear Brake Cooling Ducts (Izover4u)
:thumbs:
Mine are on order form Fichtner. Maybe a 4th of July weekend project.
Old Jun 28, 2003 | 09:16 PM
detsgt696's Avatar
detsgt696
I used a 7/32 drill bit. 7/16 is way to large.
To Rear Brake Cooling Ducts
