Driver-side hole in firewall?
Old Jun 27, 2003 | 05:26 PM
Trey395's Avatar
Trey395
Default Driver-side hole in firewall?
Is there a hole in the firewall on the drivers side? if so, where is it located?
Old Jun 27, 2003 | 06:09 PM
Mag Red Monster's Avatar
Mag Red Monster
Elite Member
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Driver-side hole in firewall? (Trey395)
To run a wire??? I used the one by the steering columnn to run the wiring for my line lock :thumbs:
Old Jun 27, 2003 | 06:59 PM
Trey395's Avatar
Trey395
Default Re: Driver-side hole in firewall? (Mag Red Monster)
Oops, yes, I meant to run a wire... :) It's been a long day, thanks!
[Modified by Trey395, 6:00 PM 6/27/2003]
Old Jun 27, 2003 | 07:08 PM
ncfierydragon's Avatar
ncfierydragon
I ran one through the trunk cable area.
Tuan
Old Jun 28, 2003 | 03:21 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Look behind or near the battery!
Old Jun 28, 2003 | 02:16 PM
Mag Red Monster
Elite Member
did you find it???
Old Jun 28, 2003 | 03:41 PM
BSiegPaint's Avatar
BSiegPaint
St. Jude Donor '06-'07
If you need to have one on the driver's side, you can drill one ( :eek: ). Remove the dead pedal and you will see a nice flat area that you can use for a hole. Easy access from under the hood, too. Did this to mine to run a wire from a remote mount radar detector.
To Driver-side hole in firewall?
