trouble light, question?
Old Jun 28, 2003 | 11:26 AM
Zturb00's Avatar
Zturb00
Default trouble light, question?
i have a 1998. very low miles. ran fine error free when i parked it.. started it this AM, n' all hell broke loose.. display said i had engine problems n' it was running limited power i also had traction control problems, as well as a suspension problem,, :mad
drove it n' it idled like hell but ran smoothly once gouing down the road.. but it had very.. lil power..
parked it then later restarted it and it seems to run fine full power smooth idle, but the ''check engine'' light stays on.. :rolleyes:
any suggestions??? it has been mentioned by a friend that i disconnect the battery.... n' see if that clears the puter codes... is this,,
a,,,,,,, ''good idea''? :confused:
thanks for your imput. :thumbs:. i'm quite new, to vette ownership.
Old Jun 28, 2003 | 05:08 PM
Zturb00's Avatar
Zturb00
Default Re: trouble light, question? (Zturb00)
it solved,,,,,,, ITSELF... :eek:
drove it bout 50 miles today, with several stops... (check engine) light went out at the first stop :smash: n' never came back on... :rolleyes:
