Headers for 97-00 vs 01-03
Old Jun 29, 2003 | 04:06 AM
RHPF's Avatar
RHPF
Default Headers for 97-00 vs 01-03
What is different about them?? I have 97 and want to buy headers from someone with an 01, what if anything has to be changed to allow them to work on a 97? Thank you, i tried searching but no luck sorry if it has been asked.
Old Jun 29, 2003 | 04:55 AM
SFVetteman's Avatar
SFVetteman
Default Re: Headers for 97-00 vs 01-03 (RHPF)
The AIR pipes are located in different spots.
Old Jun 29, 2003 | 08:15 AM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
Also the 01-03 cars have "pre-cats".
Tom
Old Jun 29, 2003 | 08:38 AM
jeanlucpicard's Avatar
jeanlucpicard
Default Re: Headers for 97-00 vs 01-03 (TCW)
Nope - only the 2001 model year have pre-cats. They were deleted in 2002.
The 2001-2003 model year oil dip stick tube is in a different orientation.
Old Jun 29, 2003 | 08:45 AM
MySea6's Avatar
MySea6
the AIR pipe on the passenger side (01 header) would have to be relocated for your 97 :thumbs:
BTW - pup cats were only dropped from the Z06 in 02
Old Jun 29, 2003 | 08:46 AM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Depends if you are talking shorty headers, or long tubes.
LT's primary difference is the AIR flange location and dipstick mounting. Precats or not makes no difference as the long tubes connect just in front of the main cats. If you have precats, they will be gone anyways.
Shorty headers are designed to bolt up to the stock flange, and in addition to the changes noted above, the angle and location of the factory flange is different. It would take a bit of work to get the flanges to mate up to the wrong year header.
Shorties don't offer much for gains anyways, I wouldn't waste the time installing even the correct year headers.
:cheers:
[Modified by Y2Kvert4me, 1:47 PM 6/29/2003]
Old Jun 29, 2003 | 04:07 PM
RHPF's Avatar
RHPF
Default Re: Headers for 97-00 vs 01-03 (Y2Kvert4me)
Sorry for the incomplete post, they are Long Tubes and for the 01. I have a 97, so AIR is on the wrong side? Can that be fixed, or changed or something? I will not be using emisions equipment so cats will not be relavent. But this is probably more work then I thought it would be.
Old Jun 30, 2003 | 01:20 AM
YOULLUZ's Avatar
YOULLUZ
My mid-year 2000 also had pre-cats.
Now it has none.. LOL :auto:
To Headers for 97-00 vs 01-03
