Where can I...
Old Jun 29, 2003 | 08:34 PM
Airwolf's Avatar
Airwolf
From: ********************* Florida's Space Coast *********************
Default Where can I...
Where can I find a place in the passenger compartment to get switched/ignition power from. I would prefer a spot on the drivers side. Any help would be great.
Old Jun 29, 2003 | 08:42 PM
lowprofiling's Avatar
lowprofiling
Default Re: Where can I... (Airwolf)
i would always go to the fuse box, and use a fuse tap w/ an inline. If not check your horn and see if it's hot or ignition
Old Jun 29, 2003 | 08:56 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Pull up the floor panel and look at the BCM (not the fuse box). Above the BCM,on the left, attached to the the tunnel is a connector with 3 unused wires -taped off with black electrical tape. You can seperate the connector and you should see a black (ground)wire, an orange wire and a yellow (?) hot accessory/ switched wire. I'm sure of the black and orange wires ...I'm not sure that the hot wire is yellow. I recenly installed an O2 Wideband setup and shiftlight using this hotwire (yellow?). Good Luck! Let us know how things go. :yesnod: :yesnod: :thumbs:
Old Jun 29, 2003 | 09:21 PM
Airwolf's Avatar
Airwolf
Default Re: Where can I... (binksZ06)
Perfect. Just what I was looking for.
Thanks and I will keep you informed!
To Where can I...
