Power steering or Water Pump!!!`
I have a leak from the engine. At first I thought it was my Power steering because of the color "Orange fluid". The leak is on the passanger side of the engine.
Yesterday since I am redoing my wheels I get under the car and see a small puddle since I had the car up on jack stands for a week. I saw the puddle grow a little. I thought there is no way power steering fluid can drip that much in a week without driving it.
As soon as I left the car up more in the air I see a drip and another. I get under the car and my spring is mildy covered with Orange color fluid. MAy I add my radiator fluid is orange as well :banghead: . LEsson have different fluid colors to determine leak.
Anyways my belts squeak as well which I looked under and saw it was somewhat covered in fluid.
I wiped it down dry and I won't be able to drive it for a while since my wheels are off and getting repaired.
This might help when I drive straight slowly like 3 mph I hear a small clunking noise or when I am going in reverse! My Power steering fluid has been filled and still full. Ahhhh!!! Some input would be nice.
Thanks!! :cheers:
Sounds like a waterpump gasket might need to be replaced, or worse, the waterpump might be going. If you have a 97 or 98 year model C5 the gaskets will be made of paper and do fail from time to time. You can use the 99+ style waterpump gaskets on it with no problem.
It should be very easy to tell the difference between power steering fluid and coolant. One will be greasy/oily, and one will be like water.
Jon
http://www.c5howto.com
Okay any info on how to replace a water pump :jester I will do a search. Cheers!! :cheers:
Here is a pic of the pump and the 6 bolts http://www.c5howto.com/howto/c5/head...ewaterpump.jpg
Jon
[Modified by jmX, 1:44 PM 6/30/2003]
Hey how is the write going for the cam install only. Been sitting on my cam since you said you were going specifically doing a write-up just for the cam.
Thanks!!
Do you think it could of been the clunking noise as well?? Thinking about replacing the whole darn thing then. Thanks!!
