Should I beef up my suspention???
Should I look into beefing up the suspention at all?? My car is totally stock as far as handling bars go??????
What would you do??
A bit more info, please.
Have a good one,
Mike
I do not have the active handling option or done anything with the sway bars. I have not replaced anything for ride control other than the shocks.
Hope that better explains what I am asking. In short would you do anything else to your car if it were yours knowing what have and am doing???
Of course, if you're wanting to get into twisty competition, then your base car is pretty darn good, but from stock I'd upgrade:
1. Z06 sway bars, front and rear
2. Bilstein sport shocks
3. Z06 springs, again front and rear.
When I was running my Vette on street tires, I had a real problem with the front end pushing. Could be bad technique, but I decided to approach the problem by putting 275s up front to match up with the 275s in the rear. Understeer problem solved! :thumbs:
Hope this helps, and have a good one,
Mike
Mike
HTH, and have a good one,
Mike
Cant wait till I go to the track for the first time with that little bit of a larger hood on my car and kick some MORE import buttox!
You mean, something like that? :D
Wish I could help out, but I don't know much about drag racing suspension, other than you'll probably need the stickiest tires you can find!
Have fun,
Mike
What would you do??
