Acid Leak Repaired
Old Jul 1, 2003 | 09:51 AM
bozo4onion's Avatar
bozo4onion
Default Acid Leak Repaired
I really want to thank all you guys for the advice concerning my acid leaky 2K coupe battery. I caught the problem just in time. There was plenty of acid corrosion but none on the harness or PCM. I used acid neutralizer first then scrubbed the entire area w/bicarb and water. Removing the access panel beneath the car is a must. Is above all the electronics really the best place to store a couple-a-pounds of hydrochloric acid. Anyhow, I used rust converter on the etched frame and even found some paint (Coronado oil base satin w/rust preventer) that has a similar texture to the factory finish. And of course a Red Top. I literally could not have done this job w/o the help of you guys on the forum. Thanks again. :hurray:
Old Jul 2, 2003 | 12:17 AM
WILDONETHIRTYSEVEN's Avatar
WILDONETHIRTYSEVEN
Default Re: Acid Leak Repaired (bozo4onion)
:cheers: :cheers:
Old Jul 2, 2003 | 05:37 PM
Sorry I Bought An A4's Avatar
lucky you. i did not catch mine soon enough. the acid ate away a vacuum line (not covered by warranty) and the dealer said that the engine wiring harness looks pretty bad. the harness is alegedly a $2,000 repair. i am going to start looking for a used one.
Old Jul 2, 2003 | 06:18 PM
LoneStarFRC's Avatar
LoneStarFRC
GTH! :thumbs:
To Acid Leak Repaired
