Re: Stealth cam and pulley install is complete (PewterC5)
Well, this motor has awaken from hibernation :D :D :D :D :D
I'm certainly no expert on cams but this stealth cam from MTI is exactly what Jason said it would be. Almost stock idle and manners but it wakes up big time under WOT. The GHL's are rumbling even better now. :yesnod:
Congrats on the Stealth Cam! I got the first one about a month ago, and it is the same for me. The car sounds the same through the Ti exhaust as it did stock, the idle is almost identical to stock, but the cam makes great mid to upper range power (2500-6000rpm).
I got mine dynoed after the cam change and install of some stage 1 ls1 heads I had left over from my '99 Trans Am. The results were:
405rwhp/375rwtq :cheers:
I may do a gear upgrade later this year to bump the low-end, but for now I'm completely happy with this setup. MTI rocks!!! Enjoy the cam!
Hey Pewter,
what are the specs on that cam, if available or appropriate. I checked out MTI's website to learn more but they dont list any "stealth cam".
Re: Stealth cam and pulley install is complete (BlueBlazer)
Yes, my azz-o-meter certainly notices the difference. Of course its hard to say how much HP I actually gained. I do know that its hard to keep traction now :D
Yep....the stealth is: 220/581/115 from above.
Congrats on the cam!
Have you noticed any charging issues with the ASP pulley? I installed an under-drive pulley on another car (Mustang) and at idle it would drain the battery. It also shortened the life of the battery to about one year.
Re: Stealth cam and pulley install is complete (SideStep)
