Clutch adjust?
Old Jul 2, 2003 | 07:36 PM
lwh's Avatar
lwh
Default Clutch adjust?
It seems that my clutch has to been at the absolute bottom of the stroke in order to have a smooth, no ratchet, shift. Are these hydrolic clutches adjustable?
Old Jul 2, 2003 | 10:52 PM
davidfarmer's Avatar
davidfarmer
Default Re: Clutch adjust? (lwh)
No, but you may need to bleed. Requires a helper and a long arm, but might fix your problem. Clutch fluid bleeds just like brake fluid, and the valve is on top of the bellhousing
