Headlights acting strange?
Old Jul 3, 2003 | 04:32 AM
Vinzvette's Avatar
Vinzvette
Default Headlights acting strange?
The last time I drove her when I turned on the lights they didnt pop up. I turned the switch off and then back on and all worked fine. The previous evening only the passenger light raised, again turned them off then on and all was fine again. Any clues?
Old Jul 3, 2003 | 05:01 AM
Grzldvt's Avatar
Grzldvt
Default Re: Headlights acting strange? (Vinzvette)
I had this, and this is purely speculative, the car sat for quite awhile and/or was rarely driven at night. It reached the point where the headlights would no longer pop up. I kept turning the switch and it worked itself out. As a guess, and it is a pure guess(SWAG), dirt/stuff gets in the switch and prevents proper contact. Twisting it many times cleans the "stuff" out and they work fine. :eek:
Old Jul 3, 2003 | 09:17 AM
George Cooper's Avatar
George Cooper
Check the hot terminal on your battery. If it is at all loose, this will happen.
Old Jul 3, 2003 | 01:12 PM
lost's Avatar
lost
Default Re: Headlights acting strange? (George Cooper)
Had a similar problem when I first got my C5, just working the switch a # of times seemed to cure it. I figured the prior lack of use allowed the switch contacts to get dirty. Just a guess on my part, but the problem hasn't reoccured...
Old Jul 3, 2003 | 03:23 PM
pmarone's Avatar
pmarone
:iagree: :iagree:
I had battery problems and it affected both lights coming up. Swapped the battery and all is fine.
Pete
Old Jul 4, 2003 | 06:05 PM
carpe dm's Avatar
carpe dm
:iagree: :yesnod:
Old Jul 5, 2003 | 10:45 PM
Bling Bling's Avatar
Bling Bling
Default Re: Headlights acting strange? (carpe dm)
I had this happen to me too. I cleaned both battery terminals with steel wool and that seemed to help.
Old Jul 6, 2003 | 08:20 AM
Soldiervette's Avatar
Soldiervette
Default Re: Headlights acting strange? (Bling Bling)
also if you wash your eng compartment make sure that there is not moisture in the conections or the headlights motors it self :iagree:
To Headlights acting strange?
