fuel pump/dual tank explaination???
Old Jul 3, 2003 | 10:17 PM
davidfarmer's Avatar
davidfarmer
Default fuel pump/dual tank explaination???
does anyone know how exactly the single fuel pump manages to keep the tanks balanced on the C5's. This is one part of the car I still haven't figured out.
Thanks!
Dave
Old Jul 3, 2003 | 10:42 PM
rbeckham's Avatar
rbeckham
Default Re: fuel pump/dual tank explaination??? (davidfarmer)
Dave - I have asked this question before, but never received an answer. The point of my question was "how do you keep more fuel in the right tank in order to keep the overall balance better."
I have to assume that there is a siphon-type arrangement between the tanks which keeps the tanks more or less equally filled. I also would like to know the definitive answer, and if there is a means of adjusting the balance between the tanks. Regards, Robert
Old Jul 3, 2003 | 10:46 PM
SFVetteman's Avatar
SFVetteman
Excess fuel pump pressure is used to create a siphon jet in the crossover that draws fuel from the right tank to the left tank. When the left tank is full, excess fuel returns to the right tank through another crossover :cheers:
Old Jul 3, 2003 | 10:52 PM
rbeckham's Avatar
rbeckham
Default Re: fuel pump/dual tank explaination??? (SFVetteman)
Now that you mention it, I recall that the problem is that the left tank is kept full, while drawing from the right tank.
This is not an optimal setup for a car with the driver on the left.
This also may have something to do with the screwy fuel guage on these cars. The question remains - how would one go about keeping more fuel on the right, or even reversing the fuel tank bias left to right??
Old Jul 4, 2003 | 01:26 AM
Godspeed's Avatar
Godspeed
Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
I can scan and post the fuel system diagrams if it would help you.
Old Jul 4, 2003 | 07:44 AM
rwj383's Avatar
rwj383
SFVetteman is correct. When i plumbed my external fuel system, i studied it close and learned all this to be true. This makes for an imperfect system, with regards to balance. At some point the pass tank becomes empty while the driver tank is full or nearly full. On my car, this happens at about 1/2 tank indicated. I found this out the hard way when i plumbed my external fuel system into the pass tank. At about 1/2 tank on the fuel gauge my external system goes dry. Our fuel tanks are almost never balanced, is the point.
robert judd
Old Jul 4, 2003 | 11:16 AM
davidfarmer
Default Re: fuel pump/dual tank explaination??? (rwj383)
The ultimate question is this, I seem to be empying my driver (primary) tank without using all of the fuel from the passenger tank. Is there a way to increase the crossover rate, so that the driver tank stays full?????
At this point, balance is not nearly as big a problem as starvation.
Thanks!
Dave
Old Jul 4, 2003 | 03:34 PM
davidfarmer
Default Re: fuel pump/dual tank explaination??? (MANNY)
I was under the impression the primary pump in the drivers' side tank, does both. There is no pump in the passenger side tank.
Other than replacing the OEM pump with a bigger unit from Lingenfelter, everything is stock.
The manual mentions a "jet pump", but I think that is an expression, and not an actual pump. If it is, please point me to it.
Dave :withstupid:
Old Jul 4, 2003 | 04:03 PM
SFVetteman's Avatar
SFVetteman
Dave, perhaps an even bigger fuel pump would increase the transfer rate, if one is available.
Otherwise, the only solution I can think of to solve your problem is to plumb in another line from the right tank to the left with a small fuel pump to assist in the transfer.
Ideally, you would want the pump operation controlled by the float/fuel sensor in the right tank so that when the right tank is dry the pump would shut off.
Old Jul 4, 2003 | 04:07 PM
Godspeed's Avatar
Godspeed
Senior Member
Old Jul 4, 2003 | 04:08 PM
Godspeed's Avatar
Godspeed
Senior Member
Default Re: fuel pump/dual tank explaination??? (Godspeed)
Dave, I asked Lou about it and he recommended just tapping the lowest point on each tank and connecting it was an AN line. Gravity will balance out the tanks - he said he used to do that in his Mustang World Challenge car years ago.
Old Jul 4, 2003 | 04:34 PM
Godspeed's Avatar
Godspeed
Senior Member
don´t get why some "specialists" above figure out their own fuel-pump-setup-inventions and base an answer on imagination. What´s the point?
:confused:
Old Jul 4, 2003 | 04:35 PM
SFVetteman's Avatar
SFVetteman
I knew if I lived long enough I would eventually make a mistake :bb Manny is right :smash: I had thought from reading the manual that the jet pump was not a real electric pump, but such is not the case.
My parts book describes it as a fuel pump and it has an electrical harness associated with it as well. The part number of the pump for a 2001 is 88895126.
It is now apparent that the your problem is most likely a bad jet pump :banghead:
Thanks, Godspeed for posting that diagram as it gave me the idea to look in my parts book.
Old Jul 4, 2003 | 05:36 PM
davidfarmer
Apperantly, the jet pump is so small I never realized it actually was a pump. I will pull the right tank apart and ispect everything. Hopefully, I can manually run the pump and check it out. If it is working properly, I may rig the right side float so that it apears "empty" to the computer, just in case the pump is shutting down due to all of the cornering and "sloshing".
Thanks for all of the help!
Dave
Old Jul 4, 2003 | 08:39 PM
davidfarmer
it jumps from near empty to half full at times.
Old Jul 4, 2003 | 09:39 PM
bowtiebandit's Avatar
bowtiebandit
Dave,
If you need some spares to play with I think I have 4 or 5 old ones laying around the shop from the dreaded fuel gauge issue.
Old Jul 4, 2003 | 10:57 PM
davidfarmer
Default Re: fuel pump/dual tank explaination??? (bowtiebandit)
I finally found it in the manual. It is indeed a venturi pump, not an electric pump. It uses a small amount of pressurized fuel from the main pump to pump fuel back to the left side. It seems like it would take more fuel to run the pump than it could pump back, if I remember my physics properly.
I am going to drain the tanks and look things over. I may buy a cheap electric pump to simply pump all fuel from right to left. I am starting to think that maybe, on certain tracks, the crossover jet pump simply cannot keep up. I get 3 miles to the gallon on track, and it may simply not be able to keep up.
Any spare parts are welcome!
David Farmer
2504 W Main Street
Albemarle NC 28001
Old Jul 5, 2003 | 01:04 AM
SFVetteman's Avatar
SFVetteman
That's what I thought from reading the manual. However, what's a fuel pump harness doing in the right tank when there is no electrical pump? The part number for the harness is the same as the one in the left tank and the parts book calls it a fuel pump harness.
I'm sure when you get the right tank apart, you'll solve the mystery. Perhaps the harness while the same as the one in the left tank only uses the wires for the fuel sensor and the fuel pump wire is unused.
Old Jul 6, 2003 | 09:41 PM
davidfarmer
Well, it is in there, but I am basically convinced that the "jet" pump simply cannot move the fuel fast enough to keep up with my needs. I am going to block off the pressurized jet "feed", and add a dedicated electric return fuel pump to pump fuel back to the primary tank. Any overflow can easily pass back up and over the top crossover.
Eventually, I want to make the passenger tank the primary, and feed into and out of it. That would help with weight. However, the in-tank pump Won't fit properly (I tried), and I don't have time before Sears Point to switch pumps.
Thanks for all the help!
Dave
To fuel pump/dual tank explaination???
