Vararam Question
Old Jul 4, 2003 | 12:07 PM
Jim Shearer's Avatar
Jim Shearer
Default Vararam Question
When the Vararam system is installed, do you keep the original radiator shroud? It looks to me like it will either have to be removed or cut in order to bring the air from the intake point to the MAF. They say "no cutting" on their site.
Also, about how long does it take to install if you have a lift?
Old Jul 4, 2003 | 03:36 PM
Jim Shearer
Default Re: Vararam Question (RG in Dallas)
Thanks for the link. I checked their site but didn't see those pics.
About how long to intsall?
Old Jul 4, 2003 | 03:53 PM
C5Cemo's Avatar
C5Cemo
Default Re: Vararam Question (Jim Shearer)
Check out Step# 12 pic on this page:
http://www.vararam.com/vr1b_install_pics01.html
You can see that the scoops will sit above the stock shroud.
...you should set aside at least 3 hours for the install. It could take a bit longer if you are unfamiliar with that area of the car's assembly.
:cheers:
[Modified by C5Cemo, 3:01 PM 7/4/2003]
Old Jul 5, 2003 | 12:50 PM
TopCat's Avatar
TopCat
Vararam told me that the unit would run $199 when I called. How much will it cost later for the snorkel pieces to convrt it to a V1B?
:cool:
Old Jul 5, 2003 | 09:50 PM
Jim Terry's Avatar
Jim Terry
St. Jude Contributor
Cruise-In III Veteran
Default Re: Vararam Question (tn_c5owner)
The shroud has to come out to install the front parts of the Vararam, but it's not cut. Like was said, it takes about 3 hours, a little cussin', but I like the finished result! :seeya
To Vararam Question
