A few cam only questions......
Old Jul 4, 2003 | 02:09 PM
Kaley@DragonRace's Avatar
0Kaley@DragonRace
Supporting Vendor
Default A few cam only questions......
Does anyone have sound clips of their cam only cars? I would like to here what they sound like. If you do can you please post what type of cam you used?
Secondly, Is there any cam on the market that gives you the same gains as the G5-x2 cam? Is 999.99 a good price for what is included in the kit? Is there another cam I can buy that will give me the same gains for less money? Thanks, kaley
Old Jul 4, 2003 | 07:40 PM
Mitch C's Avatar
Mitch C
Default Re: A few cam only questions...... (2C5only21)
Give Comp Cams or Thunder Racing a call and talk to them about what you are looking for in a cam. They will be able to help you. :cheers:
Old Jul 4, 2003 | 07:49 PM
SnowyATX's Avatar
SnowyATX
2C5only21,
I just installed an MTI Stealth cam in my Y2K hardtop. I don't have a sound clip but I can tell you that it really woke up my engine. Idle is very close to stock but has an ever so subtle lope to it...sounds really cool with my GHL exhaust. What all is in the kit you are referring to?
Old Jul 4, 2003 | 10:40 PM
vstella's Avatar
vstella
The like the Lunati products..This clip is of my Lunati 232/236-575/578-112 LSA.. :yesnod:
http://temp.corvetteforum.net/c5/vst...keridlewmv.wmv
Old Jul 5, 2003 | 01:23 AM
0Kaley@DragonRace
Supporting Vendor
Default Re: A few cam only questions...... (vstella)
vstella, will that cam work w/ my stock heads. I love the sound of that. What all will I need to use that cam if I am able to use my stock heads? Who can I use for a mail order tune? Thanks, Kaley
Old Jul 5, 2003 | 03:00 AM
Godspeed's Avatar
Godspeed
Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
Our kit also includes upgrading the valvetrain - double springs, pushrods, retainers, and seats.
If there is enough interest we may run the forum special of 899.00 for the kit again.
Old Jul 5, 2003 | 03:39 AM
alexWS6's Avatar
alexWS6
Default Re: A few cam only questions...... (Godspeed)
I'm interested...how much more $ to go ahead and make the heads stage 2?
Old Jul 6, 2003 | 08:43 AM
vstella's Avatar
vstella
vstella, will that cam work w/ my stock heads. I love the sound of that. ...... 2C5only21
Well I guess you could use it with a stock head setup although there will be some tuning issues..You really should consider a set of modified heads ..you will be leaving some serious H.P./TQ on the table and the LS1 Edit is certainly a must when installing a larger cam with A/F ratios and idlling issues.. :chevy
Old Jul 6, 2003 | 11:41 AM
LG Motorsports's Avatar
LG Motorsports
Premium Supporting Vendor
St. Jude Vendor Donor '03-'04-'05-'06-'07-'08-'09-'10-'11
If the G5X-2 cam is not your cup of tea, we have plenty of others that perform very well, and our cams have set the high water mark for the past year. Right now, the broad range, as well as the peak hp of the G5X-2 is the cam to beat. And it can be installed directly into a stock engine with just the addition of springs and pushrods. With no piston to valve issues at all.
We have a number of different cams. The G5X-2, G5X-1 G5, G2 and our baby cam which was our early G2 cam. The duration ranges from 221* to 240*, and we can supply any split or duration that would fit your requirements.
I will also advise you based upon your goals.
Give us a call at LGM
Lou Gigliotti LGM
Old Jul 6, 2003 | 03:50 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Search here, on the Forum, and LS1tech.com - Lou's G5 X2 has received great reviews by all users and dyno #s are excellent! Best PROVEN cam going with very streetable manners. :yesnod: :yesnod: :yesnod: Just my $.02 :thumbs:
To A few cam only questions......
