gm gen 3 heads/cam
Old Jul 6, 2003 | 12:24 PM
jsingh's Avatar
jsingh
Default gm gen 3 heads/cam
has anyone had experience with this set up on ls1 2002 6 speed
i understand LPE does these for GM
how about the ASA cam?
im looking for a package for my daily driver/autocross
thanks! :cheers:
[Modified by jsingh, 11:25 AM 7/6/2003]
Old Jul 6, 2003 | 12:57 PM
'97 C5's Avatar
'97 C5
Default Re: gm gen 3 heads/cam (jsingh)
With LPE you won't go wrong but the ASA cam is too much for the daily use. Check with LPE on compression ratio ( cc of heads) as you don't want to be in a position of needing fuel additives to fight knock retard issues.
Daily driver cams are generally in the 218 -224 duration range and on 114 LSA. This all depends on how sensitive you are to idle spoeed, lope and tuning.
Old Jul 6, 2003 | 06:30 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
thanks! :cheers:
Which GM Gen III heads are you referring to???
To gm gen 3 heads/cam
