502 into C5?
Old Jul 6, 2003 | 06:53 PM
dads01dream's Avatar
dads01dream
Default 502 into C5?
Hey all,
So, is this a possibility with the crate motor? If so, what's involved & can we use any stock driveline components?
Thx!
Old Jul 6, 2003 | 07:01 PM
SFVetteman's Avatar
SFVetteman
Default Re: 502 into C5? (dads01dream)
It's possible: http://forums.corvetteforum.com/zero...969165#4969165
Old Jul 6, 2003 | 07:48 PM
Richin Chicago's Avatar
Richin Chicago
Hey all,
Thx!
As long as you don't have tough emission testing in your state.
Old Jul 6, 2003 | 09:32 PM
snide's Avatar
snide
CI 4-5-7-8-9-10 Veteran
St. Jude Donor '07 thru '11
Damn! :eek:
:thumbs: :cool:
Old Jul 6, 2003 | 10:35 PM
Face's Avatar
Face
Default Re: 502 into C5? (snide)
Why would you want to add all that extra weight? Why not bore and stroke your LS1?
Old Jul 6, 2003 | 11:00 PM
'97 C5's Avatar
'97 C5
yes, it can be done.
Old Jul 7, 2003 | 01:16 AM
mapman's Avatar
mapman
502? Why go with just another "small block"? What about one of the new ZZ572 or ZZ620 engines?
620 HP @ 5500 RPM, 650 ft lbs @ 4500 RPM, 9.6:1 compression, 92 octane recommended. See page 47 of your 2003 GM Performance Parts catalog. :)
Old Jul 7, 2003 | 03:50 AM
IFLUBYU's Avatar
IFLUBYU
Default Re: 502 into C5? (mapman)
The ZZ502 is a big block. The two you mentioned are the next evolution of the ZZ502. I believe they used better parts on the top of the motor on both, the 572 is 10:1 on street gas and the 620 is 13.6:1 on race gas. I agree that I would probably go with an aluminum 429 small block first, but I would love to see how one of the big blocks work out if anyone does one!
If any of my numbers are off, anyone feel free to correct.
Old Jul 7, 2003 | 04:49 AM
mapman's Avatar
mapman
Default Re: 502 into C5? (IFLUBYU)
... The ZZ502 is a big block. The two you mentioned are the next evolution of the ZZ502. ....
I realize the 502 is a big block, the "small" block comment was my attempt at humor given the 572/620 sizes. Sorry for any confusion.
[Modified by mapman, 4:11 AM 7/7/2003]
Old Jul 7, 2003 | 10:32 AM
EuG's Avatar
EuG
I wonder how much all aluminum big block weights. :) Probably not THAT much more than an LS1. I know Danovan makes aluminum blocks for BBC.
Also I don’t see a reason to make it a 502ci If you’re putting a big block might as well punch out to like 540ci :D
I know street 540ci BBC can put out 700-800HP on pump gas and everything w/o braking a sweat.
Still, to shoehorn one into C5 most likely a ridiculous project :eek: and I doubt it’s worth it.
If GM only made a factory fit Ls1 style big block :rolleyes: …..we can always dream…..
To 502 into C5?
