Tranny cooler questions
Old Jul 6, 2003 | 09:23 PM
bgood's Avatar
bgood
Cruise-In IV Veteran
St. Jude Contributor
Default Tranny cooler questions
Hey everyone! I have a few questions here. I'm looking to install a tranny cooler on my C5 to help keep the tranny temps under control. This Atlanta area heat along with stop & go traffic is taking its toll on my tranny.
First has anyone here installed the Hi-Tek series of coolers from B&M? Here's a link to what I'm referring to: http://www.bmracing.com/products/acc...tekCooler.html
If so, which model did you install?
Now for those of you that have installed a tranny cooler.... Is there a good write up on a C5 cooler install? I've seen mention of them on here, but no real write up. I'm mainly interested in making sure I connect the right tranny lines to the right places on the cooler.
Any suggestions, comments, donations, or help is appreciated. :D
Old Jul 6, 2003 | 09:31 PM
Bill Dearborn's Avatar
Bill Dearborn
Default Re: Tranny cooler questions (bgood)
Are you talking the 6 speed or an automatic? GM makes a cooler for the 6 speed that uses a Fluidyne cooler and a Weldon pump.
Old Jul 6, 2003 | 09:37 PM
bgood's Avatar
bgood
Default Re: Tranny cooler questions (Bill Dearborn)
I'm referring to the auto.
Old Jul 7, 2003 | 03:48 AM
gary brown's Avatar
gary brown
From: Los Angeles Founder, West Coast Corvette Challenge
Brian - about a couple of months ago I was going to have the new Hi-Tec B&M tranny cooler installed. Slight problem when we took it out of the box - you can't mount this fan on the front of the condensor because the fan is designed to PULL air as opposed to PUSH air.
There isn't any room to mount this fan behind the radiator as that space is already taken up by the two stock fans.
Plan B: I went with the B&M racing tranny cooler - this was an upgrade from their 24000 GVW fan. That, coupled with the aluminum B&M deep tranny pan and replacing tranny fluid with AMSOIL has really done the trick for me. Very cool tranny temps even in 100* + heat.
Hope this helps.
Gary
[Modified by gary brown, 12:51 AM 7/7/2003]
Old Jul 7, 2003 | 09:28 AM
bgood's Avatar
bgood
Default Re: Tranny cooler questions (gary brown)
This is what I'm looking for... Thanks for the info.
Hope this helps.
Gary
Old Jul 7, 2003 | 12:55 PM
carpe dm's Avatar
carpe dm
I wonder what type of connections they used on the cooler lines? Slip on hose and clamps, or something else?? I want to do this too. :rolleyes: :)
Old Jul 7, 2003 | 01:00 PM
BLUBYU2002C5's Avatar
BLUBYU2002C5
Im also in the process of doing this, maybe this weekend comin up or something any one have any good instruction on how to mount, install, connect the lines??? :lurk:
Old Jul 7, 2003 | 08:25 PM
383LPE's Avatar
383LPE
its low pressure and clamps are fine, also mobile 1 ATF runs cooler. Just run it in series with the cooler lines at the radiator.
To Tranny cooler questions
