Cont'd problems...Code 10 PCM PO 200 H C
Old Jul 7, 2003 | 06:02 PM
bojangles's Avatar
bojangles
Default Cont'd problems...Code 10 PCM PO 200 H C
The Vette is running rough... It's hard to start (like it is flooding) and
there is a strong smell... The 'check engine' light comes on after every
start and then I need to clear to clear the code 10 PCM PO 200 H C.
Any suggestions?
I took it to the dealer and they could not find anything wrong.
Thanks for your help
Old Jul 7, 2003 | 06:49 PM
mapman's Avatar
mapman
Default Re: Cont'd problems...Code 10 PCM PO 200 H C (cares)
Any suggestions? I took it to the dealer and they could not find anything wrong. ....
P0200 is set when the Powertrain Control Module (PCM) detects an incorrect voltage on a fuel injector control circuit and the condition exists for more than 5 seconds.
The PCM enables the appropriate fuel injector on the intake stroke for each cylinder. Voltage is supplied to the fuel injector and the PCM controls each fuel injector by grounding the control circuit by means of a solid state device called a "driver". The PCM also monitors the status of each "driver" and if the PCM detects an incorrect voltage, the P0200 code is set.
When the code is set the PCM records the operating conditions at the time of failure. This information is stored in memory for future reference by the mechanic.
Is this problem intermittent?
P0200 can be caused by a variety of problems, for example: a short to voltage, an open or high resistance circuit, poor wire connections, a short to ground, a problem with the fuel injector itself, or a problem with the PCM.
If the problem is intermittent, there is a procedure for the mechanic to follow. If you had the problem when you started the car at the dealership then I don't understand why they couldn't find anythin wrong. A history of what went wrong is stored in the computer's memory, the mechanic can extract that information as an aid to diagnosis. P0200 has a detailed procedure in the service manual to run fault isolation.
I would take the car to a different dealership for repair. Given what you have described, you should trust that dealer's statement that they cannot help you - stay away! (And tell your friends to stay away!)
Old Jul 7, 2003 | 08:33 PM
bojangles's Avatar
bojangles
Default Re: Cont'd problems...Code 10 PCM PO 200 H C (mapman)
Mapman,,,,,,, thanks,,,,, I'm taking your response to the dealer and ask them
why they didn't know this..
thanks, again.
Old Jul 8, 2003 | 10:52 AM
mapman's Avatar
mapman
why they didn't know this......
I would find a different dealer. These guys don't seem to inspire confidence. Why let them experiment with your car? I would believe them when they say they can't help you.
Old Jul 8, 2003 | 03:09 PM
gpflepsen's Avatar
gpflepsen
Cruise-In II Veteran
Just to add to this thread, how many verify that a dealership has a Corvette certified technician before they allow them to work on the car? I'd check that too.
Old Jul 8, 2003 | 03:12 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: Cont'd problems...Code 10 PCM PO 200 H C (gpflepsen)
Is there a corvette certification? Humm didnt even know it existed?
:confused:
Old Jul 8, 2003 | 03:21 PM
gpflepsen's Avatar
gpflepsen
Default Re: Cont'd problems...Code 10 PCM PO 200 H C (ICULUKN-C5)
The tech at my dealership has a corvette endorsment. I'll look more into it and see what that means.
Old Jul 8, 2003 | 03:30 PM
gpflepsen's Avatar
gpflepsen
Re: Tech Corvette Certified
I guess GM just stopped doing specific certifications. They used to have Corvette and Cadillac and not sure what else. They have lumped the training into a single course now. This must have happened in the last 12-18 months.
Old Jul 8, 2003 | 08:35 PM
bojangles's Avatar
bojangles
Mapman...... thanks again....I took your information to another dealer
and he read the information... replaced one injector and the PCM computer
but the Vette runs great...
Oh yeah, it cost $739.00 but it was all covered under my extended
GM warranty plan ($200.00 ded). It should run good through western
South Dakota on the way to the Black Hills Classic.
Thanks, again
Old Jul 8, 2003 | 08:58 PM
molon labe's Avatar
molon labe
this problem is usually associated with the lame injector wiring harnesses. first thing to check is the wiring harnesses - look for loose wires, pinched wires, broken or detached wiring harness brackets (gray plastic - 2 on each side).
To Cont'd problems...Code 10 PCM PO 200 H C
