Jacking up the car... do I need pucks?
Old Jul 7, 2003 | 11:39 PM
MacMan's Avatar
MacMan
Default Jacking up the car... do I need pucks?
I'm going to have the car up in the air a lot in the coming weeks though I haven't jacked it up before. I've seen jacking pucks that some of the venders are selling.
Do I need pucks if I'm using floor jacks?
Do I need pucks if I'm using a lift?
Thanks!
Old Jul 8, 2003 | 12:15 AM
Barely Legal's Avatar
Barely Legal
Default Re: Jacking up the car... do I need pucks? (MacMan)
If you are going to put it on a lift, jacking pucks should be used. There are 4 points in the bottom of the groud effect under the rocker panel for jacking with a lift.
On the other hand, they are not really necessary when jacking from the subframe. I've seen cars properly jacked several times without a hint of a mark on their underside.
Old Jul 8, 2003 | 12:39 AM
SHOWTIME!'s Avatar
SHOWTIME!
NOT IF YOU LIFT ON THE CROSSMEMBER
NO
Old Jul 8, 2003 | 12:53 AM
corvette dave's Avatar
corvette dave
Jacking pucks are the best way to go although I have used a block of wood for many years on the rocker panels without a problem.
I recently purchased 2 hockey pucks which work really well. Cost $1 each.
Dave
Old Jul 8, 2003 | 03:51 AM
FunDriver's Avatar
FunDriver
Veteran: Marine Corps
Default Re: Jacking up the car... do I need pucks? (corvette dave)
If you get some rocker rails (I believe that's what he calls them) from Andy at A&A Corvettes, you don't have to worry about jacking it up by the rocker panels---or even if you're not around and someone else jacks it up.
If you use a floor jack and place in on a cross-member you don't need any pucks but my floor jack is just a bit too tall so I use Frederik's little jack to initially jack it up and then use the floor jack.
Old Jul 8, 2003 | 04:33 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Default Re: Jacking up the car... do I need pucks? (FunDriver)
It just depends on where you are and the lift mechanism that they have, most of the times it does not matter, but you never know.
On Jacking Puck
[Modified by wallstAL, 1:35 AM 7/8/2003]
[Modified by wallstAL, 5:34 PM 7/8/2003]
To Jacking up the car... do I need pucks?
