Fuel Filler Leak
Old Jul 7, 2003 | 11:45 PM
BobFather's Avatar
BobFather
2nd Gear
Default Fuel Filler Leak
After some spirited driving at a local autocross with a full fuel tank in my 1989 Corvette, I discovered that gasoline had leaked out in the area of the fuel filler cap.
The cap itself was still able to seal (pressure was released when I removed it), but there was gas under the filler cap door and all over the rear body.
Any ideas what the problem could be and how to fix it?
Thanks in advance.
Bob
Old Jul 8, 2003 | 09:35 AM
carpe dm's Avatar
carpe dm
Default Re: Fuel Filler Leak (BobFather)
Next time you run, do so with less gas in your tank. Sounds like some came up from the filler drain hose. :)
