How do you removed the inside rear-view mirror?
Old Jul 10, 2003 | 10:40 AM
5150 BRD's Avatar
5150 BRD
Default How do you remove the inside rear-view mirror?
I want to hardwire my radar detector into the mirror and also attach it to the mirror. To do that it must be removed. How? As you can see from my sig the car is an AE so it has a little different configuration than some earlier C5 models. Thanks for the help.
[Modified by 5150 BRD, 7:41 AM 7/10/2003]
Old Jul 10, 2003 | 11:14 AM
AnteVenom's Avatar
AnteVenom
Cruise-In IV Veteran
Daytona Jam 1 Veteran
Default Re: How do you remove the inside rear-view mirror? (5150 BRD)
Not sure but some rear view mirrors are held on with an allen screw that tightens up against a bracket that is glued to the window.
If that is the case you would loosen the screw and the mirror should come off.
:cheers:
Old Jul 18, 2003 | 10:43 AM
5150 BRD's Avatar
5150 BRD
TTT
Old Jul 18, 2003 | 12:14 PM
Kenny94945's Avatar
Kenny94945
Service Manual pg 8-923
1 - Disconnect electirc connector 2 - Loosen mirror mount tension screw 3 - Slide the morror up off the mirror bracket.
To How do you removed the inside rear-view mirror?
