Battery Replacement????
Old Jul 12, 2003 | 07:06 AM
Richard9933's Avatar
Richard9933
Default Battery Replacement????
Hello,
I have a 2000 c5 with only 7000 miles. Should I replace the stock battery? If so what brand?
Thanks,
Richard
Old Jul 12, 2003 | 07:28 AM
titopr's Avatar
titopr
Default Re: Battery Replacement???? (Richard9933)
That would depend since you dont use it much it could still be good. You should go check it at a reputable store. They usually check it for free so they can sell you a new one. If you decide to change make sure it has at least the same amperage as the oem and that it is COMPLETELY SEALED.
Old Jul 12, 2003 | 07:29 AM
Oldvetter's Avatar
Oldvetter
Your 2000 should NOT have an AGM battery. I would (and did) replace it. Use an AGM or Gell battery.
Don't take a chance, any regular lead-acid battery can leak. I had a DELCO leak in a new Pontiac Bonneville. In your C5 if it leaks, the computer and the wiring harness can be toast ! They are located directly under the battery.
I replaced my DELCO with a Champion XLT (AGM Battery) size/number DT35/CHXDT35 made by Exide. Got it at SAMS Club for $90-95. It has 690 CCA, 850 CA, a 36 month free replacement and free jump-start, and a 108 month limited warranty.
Old Jul 13, 2003 | 08:11 AM
Richard9933
Thanks for the info guys.......
Richard
To Battery Replacement????
