Clutch bearing
Old Jul 12, 2003 | 07:36 PM
Red Det's Avatar
Red Det
Default Clutch bearing
Dealing says whistleing noise is the throw-out bearing ('99 coupe w/17k) and plans to replace with new slave cylinder assembly next week. Since GM has new part numbers for slave and master cylinder, do you have to upgrade the master cylinder also, or will the new slave cylinder work with the old master?
Old Jul 14, 2003 | 08:34 AM
Pat97Vette's Avatar
Pat97Vette
Default Re: Clutch bearing (Red Det)
The old master cylinder will still work just fine.
